W204 error messages....
coventryslk
Coventry
W204 CDI Sport
Morning,
Not been on here for over 2 years due to personal stuff going on and nonsense I didn't need, or want. I been ok for past 5-6 months now since circumstances changes.
I've had error messages appear in past week or so that had cleared once turn off ignition and on again
They are
Power assisted steering system fault
ABS, EBV, ESP fault
Run Flat Indicator fault
Power steering....stops working etc. What could this be caused by?
Most likely a wheel sensor giving a bad signal.
Could be failing sensor, dirty sensor, dirty or damaged wheel reluctor, broken sensor wire.
To be certain (and identify which sensor) it needs codes read with Star or similar.
coventryslk
coventryslk
Coventry
W204 CDI Sport
Booked it in with mercland on Wednesday, see if they can sort it
starrzo
Belfast
w204 - C220 CDI
I unplugged the ABS module and plugged it back in and this has gone away. I had read elsewhere that people have had these symptoms (which kick in at around 15 mph) and they have blasted this connector with contact cleaner and had success.
I read the codes with my iCarsoft, of which there were two:
6264: Fault in CAN communication with control unit Engine control module
5001: Control unit N30/4 ( Electronic Stability Program control unit ). Internal Fault.
I'll see how it goes.
This video was a help:
PWMS
C180
Many thanks. Sounds promising.
