W207 intermitantly not starting
Ian Jones
E class 350CDI w207 2010
Hi, I am new to this forum, so if I get something wrong please excuse until I get used to it.
I am having alot of issues with a w207 3.2 which will very intermitantly not start, it seems to be worse in warmer weather.
A full list of codes generated are listed below (Autocom software)
Fuel (Fuel pump control unit - FSCM (Fuel pump control unit) - MT/AT)
DTC Description
C427 - No or incorrect CAN message from control unit EZS
- No symptom
- Intermittent
Diesel (642.836 - CR6 - MT/AT - 207.322)
DTC Description
102F - Terminal 15 signal on the CAN bus is missing or faulty
- Intermittent
Brake (ESP (Electronic Stability Program) - ESP (Electronic Stability Program)
- MT/AT)
DTC Description
474C - No CAN message was received from engine control unit
- Intermittent
4755 - No CAN message was received from engine control unit
- Intermittent
6307 - Engine control unit; internal fault
- Permanent
630A - Engine control unit; internal fault
- Permanent
6310 - Engine control unit; internal fault
- Permanent
6A40 - Fault in CAN communication with control unit Front SAM with fuse and relay
module.
- Intermittent
Instrument (Audio COMAND display (Central information display) - DISPC_204
(Central information display) - MT/AT)
DTC Description
No fault codes
Instrument (Instrument - IC (Instrument) - MT/AT)
DTC Description
U010100 - Gearbox control unit communication fault
- Intermittent
U118A00 - Xenon lamp left, faulty signal
- Intermittent
U118B00 - Xenon lamp right, faulty signal
- Intermittent
Climate (Climate control - HVAC_212 - MT/AT)
DTC Description
No fault codes
Gearbox (Gear selector - TSLM_204 (Gear selector) - AT)
DTC Description
No fault codes
Gearbox (Gearbox - Gearbox - AT)
DTC Description
No fault codes
Immobiliser (Immobiliser - EZS/EIS (Immobiliser) - MT/AT)
DTC Description
No fault codes
Restraints (Beltpretensioner - RBTMFL_204 (Pretension front left) - MT/AT)
DTC Description
No fault codes
Restraints (Beltpretensioner - RBTMFR_204 (Pretension front right) - MT/AT)
DTC Description
No fault codes
Multifunction (Audio COMAND operating unit (Audio / COMAND operating
unit) - CTRLC_204 (Audio / COMAND operating unit) - MT/AT)
DTC Description
No fault codes
Multifunction (Central gateway (Gateway) - CGW (Gateway) - MT/AT)
DTC Description
No fault codes
Multifunction (Doors - Driver door - MT/AT - DMFL)
DTC Description
No fault codes
Multifunction (Doors - Passenger door - MT/AT - DMFR)
DTC Description
No fault codes
Multifunction (Head unit - HU_204 (Head unit) - MT/AT)
DTC Description
No fault codes
Multifunction (Headlights - Headlight left side - MT/AT)
DTC Description
No fault codes
Multifunction (Headlights - Headlight right side - MT/AT)
DTC Description
No fault codes
Multifunction (Multifunction Camera - MPC212 (Multifunction Camera) - MT/AT)
DTC Description
C146 - CAN; communication fault with central gateway control
- no message
- Intermittent
- Unknown status
- Intermittent
Multifunction (Parking assistance - PTS (Parking assistance) - MT/AT)
DTC Description
C401 - CAN communication with the engine system is faulty
- Intermittent
C100 - Interference in CAN communication with engine
- Intermittent
Multifunction (Rear control unit - CRCM_207 (Rear control unit) - MT/AT)
DTC Description
No fault codes
Multifunction (SAM - Front (Signal Acquisition and Control Module - Front ) -
SAMF_212 (Signal Acquisition and Control Module - Front ) - MT/AT)
DTC Description
B2121 - Circuit 15R relay 1
- Unknown status
- Permanent
U0121 - CAN: communication fault with ESP (Electronic Stability Program)
- Intermittent
Multifunction (SAM - Rear (Signal Acquisition and Control Module - Rear) -
SAMH_212 (Signal Acquisition and Control Module - Rear) - MT/AT)
DTC Description
B21F2 - Terminal 15
- Faulty signal
- Permanent
Multifunction (Steering wheel electronics - SCCM (Steering column module) -
MT/AT)
DTC Description
No fault codes
1. The codes are only generated after a non start situation.
2. Car can start perfectly for 4 or 5 weeks and then start playing up
3. Once started the car Runs fine with no problems.
4. when ignition turned on the instument display does not show a selected gear (i.e P for park) the car will not start.
5. sometimes the gear selected does show (i.e P car is in park) however car will not start and cooling fans run at high speed.
6. Then next time key turned instruments can indicate P no cooling fans running and car will start normally.
Video of fault below
Any body had this fault or any clues appriciated
cheers Ian
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome Ian
What code reader do you have?
The one that sticks out is gearbox control unit communication intermittent, i wonder whats happening there
Do you have a good Mercedes indy you can get it on Star- not sure where you're based
I
Ian Jones
Thanks for reply, Have got a CMT advanced, with laptop based software. Dont know of any local indy mercedes workshops. Based in Telford Shropshire.
I was thinking of a front sam fault or engine ECU, if you clear all the codes all stays fine untill a no start situation and then all codes return at the same time, this sounds like a power not getting somewhere issue or a relay not energizing, which then cases faults to be registered in many systems.
John Laidlaw
Wirral
Closest I guess would be Andy Gayle in Smethwick
It does need Star, the generic non specific Mercedes ones don't work so well...
