The 'exterior lighting bulb failure' indicator lamp has been coming on quite frequently, the problem usually being with one of the side lamps (same housing as full beams - light switch to position 1?).
Tonight, neither of the lamps will come on but the license plate lights come on fine, as do the instrument cluster lights. I don't think the problem is with the bulbs though, because the full beams come on when I push the 'combination switch' stalk forward, and I assume they're the same bulbs (?)
Anyone seen this happen before?
Also - does the orientation of the bulb matter when you insert it into the socket? Do they have polarity?
