Calle1
- Apr 27, 2018
- r230 sl500 -02 / w210 e220 cdi -00
Hello,
Just bought a MB E220 cdi with a faulty transmission.
I got it real cheap and I already counted for buying a new gearbox.
However, before ordering a heavy 722.6 with torque converter and dragging it to the workshop I thought it could be worth asking here for input if the problem might be related to the conductor plate that i read about or something else.
The problem is that the car does not always move when putting the gear lever in D or R.
When pressing the gas pedal it does not rev like if it was in N or P, it only revs a very little or not at all. No whining or other wierd noises. This happens about every second time the car is started.
It is not possible to get the car moving by putting the gear level to P/N and then back to R/D.
The only way to get the car moving again is to turn of the ignition and restart the engine.
I haven't had the opportunity to try it in higher speeds yet - also avoided it just in case the car should stop moving completely..
At first I was convinced it was a mechanical problem but the fact that the problem is Intermittent makes me think it could aso be some kind of electrical problem?
Thanks in advance.
Thanks in advance.
