W210 central locking/window problem
Spadge10
New Registration
1997 E240
Hi I'm having a confusing problem with my 1997 (r) E240 All works fine for a few days then the key will not remotely unlock/lock and I have to use the metal slide out key. The dash door lock switch works fine and the internal boot opening switch works OK. I have fitted new battery's in the key but no results. By disconnecting the main battery + cable and re-connecting after a few seconds everything is back to normal then 4/5 day later it all stops working again - it's driving me mad. I would very much appreciate some help with this problem.
it is worth checking the pse unit. it is mounted in foam encapsulation next to the battery. have a look to see if there is any moisture in the plugs or in the area generally.
does anything else fail? like intermittent window faults?
Is this also the case when you point the remote right into the drivers door handle
