W211 220CDI Error Code P0183 Fuel Temp sensor
malloryn
cambridge
E-Class / 2007 / 2.2 CDI
Motor : 2007 W211 220CDI
The MIL light has been coming and going for a while now with some temporary ( about 1-2 secs ) power loss whilst cruising.
A read of the error codes gives P0183 - "Fuel Temperature Sensor A circuit high"
To test this, I cleared the code to clear the MIL light, started the engine and no error codes appeared. I then unplugged the temp sensor, started up and again the P0183 is back.
From looking at the service book the fuel filter hadn't been replaced ever ( no ticks in the boxes). So this was changed.
Cutting open the old one showed a black sludge about 1mm deep on the dirty side of the filter, so obviously bad.
Running the car again and the MIL light still appears, however the power dips don't seem to have come back.
So I'm thinking of replacing the sensor, but where to get one from?
EuroCarParts don't stock it and I don't want the MB premium.
So, does anyone know where to get one?
and
Is this a known / common failure point or indicative of something else?
Steve@Avantgarde
Bristol/Somerset
I would say get it to an Indy who has access to STAR. I dont recognize the fault code and no its not common. I would guess your generic reader has translated a code which wont match the STAR code, could be wrong.
M
malloryn
cambridge
This was been done at the last service with the same error but, I think it was misread as coolant temperature sensor, a more common fault. So I went away and changed the coolant sensor
star
Reading
Smart + others :)
we replaced a fuel temp sensor last week, 1st one we've ever changed.
EdGus
Hednesford Staffordshire
E220 Bluetec Night Addition
Update on my fuel temp sensor. It was replaced had no further trouble with it. This was picked up on my hand held diagnostic meter. Not star?
coventryslk
Coventry
W204 CDI Sport
Where was it located and was it easy to do?
aycee
Headley, Hampshire
Black CLS350 W218, Blue SLK320 R170, Silver A Class W169
My brother changed one on his w204 a couple of months ago. Think he said it was on the injection pump but don't quote me! :???:
coventryslk
Coventry
W204 CDI Sport
Issue has resolved itself.... filled the tank end of Last week and no eml on at all. Must have been something with the fuel in the tank prior?
coventryslk
Coventry
W204 CDI Sport
I spoke to soon. It's back
I used to have the same slk as you nice colour
aycee
Headley, Hampshire
I can contact him if you need any further info.
Sad days, the SLK's been off the road for 3 weeks, problem with the DAS. Waiting on Mark @ RMK to work his magic.
magneticman
Manchester
W204 C220cdi Sport
Hi guys im realy strugglong with this and its driving me nuts im also trying to find the fuel temp sensor but had no luck please sumone help...
mersum1es
Finland
dickybow
Birmingham
C200
Bump - does anyone know where this fuel temp sensor is located on the W204 C CLass??
dickybow
Birmingham
C200
I think it is this ?
I think it is
