W211 220CDI which engine oil?
dursleyman
Dursley, Glos
2005 E220CDI Elegance Estate, 1977 Triumph TR7 FHC, 1980 Triumph TR7 DHC
Time for an oil and filter change on our 2005 W211 220CDI estate and I wondered what engine oil is recommended.
Our specialist, who I can't get to at the moment, always just puts Castrol GTX Magnatec on his invoices but there are several versions of it.
Which one do folks recommend please?
onefortheroad
uk.
As above or vw/audi oil for pd engines.
Gazwould
C250 CDI
Three PD specs though !
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
Fuchs TITAN Supersyn 229.52 SAE 5W-30
Look for it at Opie Oil
MJJ
Wiltshire
'09 S211 E220 Cdi manual - 216k miles and counting
Something that meets 229.51 MB spec
These 20l cubes from the Mercedes dealers are great. Oil to the right spec, very good value, and in a great container with an easy use tap - all straightforward to recycle. Great invention. Does nearly three oil changes on the W211.
Martin.
M80
Derbyshire
Any oil that meets 229.51 spec.
You will need 6.5 litres.
Choose a good oil filter, eBay will help you be sure it's the correct fit.
Consider buying an oil extraction pump it makes the job much easier. A problem is many are only good for 6 litres.
Be ready with cloths for any spillage.
A funnel is a good idea when it comes to refilling, wrap cloths around the oil filler, and pour slowly or it will gurgle back at you.
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
As others have said MB229.51 either 5w-30 or 0w-30.
We do oil and filter service packs, just put your reg in https://www.opieoils.co.uk/
Cheers,
Guy
