W211 320 CDI Poor Cold Starting
Made_in_Stuttgart
W211 E320 CDI
Recently purchased a 56 reg E320 CDI.
Superb car, however even after replacing all six glow plugs it struggles to start in the morning.
When it fails to start a plume of white smoke emits from the exhaust. It starts perfectly the second time round and indeed during the rest of the day.
What could be causing this?
Cheers.
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
Air in the fuel pipes ? - pull back the protective and have a look while someone cranks it over.
If so, a number of possible areas but from my 1st hand experience, it is one of the o-rings on on one of the fuel lines.
A more technical answer will follow I am sure though.
M
Made_in_Stuttgart
W211 E320 CDI
Thanks for that.
It's going back to the garage tomorrow, I will mention your suggestion.
_Taz_
Kent
2011 E63 6.3NA AMG Tenorite Estate MCT 7g
sounds like a leaky injector, perhaps..
Corned
East Midlands
2005 S211 E320CDI Avantgarde
What does the white smoke smell like? My guess (and that's all it is) would be uncombusted diesel, so either leaky injector(s) or faulty glowplug relay.
Air in the pipes would not produce smoke.
walsi
North Cornwall
www.ncmcc.co.uk
Vito 120 V6 CDI 2007 chipped and lowered :)
My vito puffs out a little cloud of white smoke in the morning if you just jump in and turn the key, if you let the glow plugs run for as little as 10secs it doesn't. Its more noticeable because i have a short straight through exhaust so no silencer to impede its progress.
Martin
M
Made_in_Stuttgart
W211 E320 CDI
The glow plug light goes out before I attempt to start.
The garage told me they replaced the plugs, maybe it's something to do with them but not actually the plugs themselves?
walsi
North Cornwall
www.ncmcc.co.uk
Hi ya, you would know if it was a fault with the glow plugs because either the light would stay on permanently or would go off and come back on again to tell you. Have you tried turning to the glow position and then counting to 15 and then turning the key to see what happens ??
Martin
M
Made_in_Stuttgart
W211 E320 CDI
No not let it go for 15 seconds, shouldn't need to - I didn't have to in all the previous diesels I've owned.
I did test something this morning - put it into on but didn't start, waited for glow plug light to go off, then did it again. Started first time but really struggled.
walsi
North Cornwall
www.ncmcc.co.uk
Hi, the only reason i suggested waiting 15secs is that it might have cured the puff of smoke. I think you have either a leaky injector or a very small air leak in a diesel line, i would guess its losing pressure over night and this is causing the longer cranking time. If it was me i would get a leak off test done, a fuel pressure test and also check the diesel lines before you start first thing and look for air bubbles
Martin
M
Made_in_Stuttgart
W211 E320 CDI
It's been diagnosed as a problem with the glow plug relay.
Thanks for your inputs, will let you know what it's like once done.
M
Made_in_Stuttgart
W211 E320 CDI
Update for those interested.
The glow plug control unit/relay (not sure of the official term) was replaced around a week ago and I've not had the problem since (touch wood!)
Thanks for your inputs!
jp
Wimbledon
2007 E280 sport estate. Aprilia RSV1000 Tuono, CCM 404, Mk1 le mans
Just started having problems starting: the engine turns over a few times before "catching".
This morning, first real frost, the engine turned over 10+ times before starting.
Called my local Indy and 20 minutes later the Star thingy said it was a faulty glowplug relay.
Just found this post so am happy that the problem will soon be resolved :)
Mr Filipov
Huntingdon
2017 BMW 535d Gran Turismo
Around £100-£120 from memory when I did it on my CLS
6cyl
The world
CLS320 CDI
Good, not too onerous. Hopefully it's the relay and not leaky pipes or leaky hpfp.
It was ok this morning.
If its leaky pipes parking uphill/downhill can have an influence.
Parking nose down hill will start better than nose up hill.
6cyl
The world
CLS320 CDI
Where I park, the front of the car is at a slight downhill angle, approximately 3degrees. From the symptoms described in this and other threads, I suspect an intermittent glow plug relay. All 6 glow plugs were changed last Nov.
andrew056
Devon
1993 SL320 gone but not forgotten , 2004 240 CLK cabrio, 2006 ML 320cdi gone, GLC AMG 43
If this is a V6 OM642 engine and it still has the original relay then that is almost certainly your problem , easy fit and you can now get one for about £100 which is a lot less than I paid for mine a couple of years ago.
