dursleyman
- Dec 17, 2006
- Location
- Dursley, Glos
- 2005 E220CDI Elegance Estate, 1977 Triumph TR7 FHC, 1980 Triumph TR7 DHC
I am getting the dreaded red battery alarm with Visit Workshop message on our W211 2005 estate and a 9071 diagnostic code.
The alternator and battery control relay were both replaced by my local specialist in 2018 and I fitted new main and auxiliary batteries last year.
The 9071 code says "Component K57/2 (auxiliary battery relay) or the signal wire to the component is faulty"
Is it possible to test the battery control relay or do I have to just try fitting a new one to see if that fixes the fault?
If it's the signal wiring that sounds like a messy job.
With the engine running I see 14.1v on the live (red) terminal on the relay but only 12.4v on the other so it's obviously not switching on to charge the auxiliary battery.
I need to find if that actual relay faulty or the signal wire.
