james2747
- Jan 26, 2011
- Location
- Newent, Gloucestershire
- E270 CDI 2003
As anyone that has a W211 E class will know, the original sidelights are pretty feeble. I changed the old little 5 watt lW5 halogen bulbs for some new LED bulbs and they were much brighter and whiter. Unfortunately, after only a few weeks I noticed the LED bulbs would have a distinct 'flickering'. It wasn't constant and appeared to get worse when the lights had been on for a while. I eventually had to change them as they flickered so badly that quite a few people thought they were intentionally flashing (sidelights??). As I was pleased with the improved light performance of the original LED's prior to them starting to flicker, I purchased some new 'branded' LED bulbs (i.e. not cheap Chinese stuff) .... however, after about a month, the flickering started again ... and the actual LED bit fell off on one of the bulbs ... I assume to heat melting the solder on mini circuit board.
Am I just unlucky or is there something else going on I don't know about? LED's are fitted as standard items on many new cars now and I can't believe they all start flickering after a few weeks of use. Any guidance welcomed ... or suggestions as to what brand of LED's to purchase.
