w220 s class suspension fuse location?
lovemerc
South Wales
ML250 GLE AMG Sport. Previously - SL500 R230 2003 & S430L W220 1999.
As I am still experiencing a 'painfull' overnight battery drain (which may be related to the airmatic pump waking up), can anyone please tell me where the fuse is for it? I can then pull it overnight and see if it makes any difference...
Also, the location of the fuse for the air con as this has a problem and I need to pull it until it goes in to be looked at?
Thanks.
W220 1999 S430L
fuse 5 and 9 is the suspension control, 31 and 32 also for the pump. 47 for the air con
L
lovemerc
South Wales
Thank you Malcolm.
Excuse my layman ignorance, but can you also let me know which boxes these are contained in please?
Thank you Malcolm.
All fuses that I put up are in the two front boxes under the bonnet
L
lovemerc
South Wales
Thank you very much Malcolm, will get cracking on it.
L
lovemerc
South Wales
Hmmmmm,
Lots of fuses in two boxes under bonnet...
Is there anyway of finding out which number each of them are?
There are numbers by each fuse
L
lovemerc
South Wales
I have looked each side, where possible and can see very few. In fact, only two 28 & 30... on the left side box. The right box is packed and can't see any number anywhere on any of them.
Can I get some pics or perhaps a manual for these?
Its quite a lot of work,,but I will print off the two front boxes as soon as I can
47p2
Scotland
These instructions are for RHD British market cars
Air suspension is fuse 9 which is located in driver side fuse box under the bonnet 4th fuse from the top left, 30 amp green fuse.
Also fuse 32 which is located in passenger side fuse box under bonnet 2nd fuse from top left, 40 amp amber fuse.
Suspension compressor is fuse 32 as above
L
lovemerc
South Wales
Thank you 47p2, i will look at this tomorrow. Do you have a route to fuse 47 for my air con?
(Malcolm let me check this out to see if I can find them, unless you have already done it, and I will update accordingly.)
Cheers.
47p2
Scotland
Fuse 47 is located in passenger side fuse box under bonnet 3rd fuse from top right, 10 amp red fuse.
L
lovemerc
South Wales
Had a look but not as described on this car i'm afraid.
The top right section in a yellow module of three circuits, one of which has a 10a red fuse in it. Then a red module which could be containing the air con fuse.
All a bit confusing to me...
Any other thoughts to help?
47p2
Scotland
I should have said Drivers side....Sorry
