W220 S500 AMG Alloys BOLT SIZE?
MRN1K
W222 S350d, W210 E55 AMG, W204 C Class
Hi All. Hope you are well.
Can anyone help me identify what bolt size I need for my W220 '53reg' S500 with the factory 5spoke AMG Alloys. It has a factory AMG kit and wheels.
Many thanks
Nik
M
MRN1K
I have. Even the tyre place measured them but a couple different sizes. So just needed to know the correct size.
MB parts dept ? They would supply the correct ones
Craiglxviii
Cambs UK
There aren’t a “couple different sizes” on your car. The hub will only take one size.
mioba
Nottingham and Köln
Could be that you have some spare wheel bolts in there (usually shorter and steel specific - if you have a steel spare), Go to MB and get the right ones with your vin. about 3 pounds each
Change them they look rusty, but I am OCD :)
M
MRN1K
Thanks All. Yep the plan is to change them all. MB parts were not very helpful locally so going to try another dealership!
Wheels just had a full refurb so want to change all the bolts anyway so they look good!
M14 x 45mm shaft with R14 head.
Pull out a bolt and measure the length of the bottom of the radius to end of the thread. Should be about 45mm.
mioba
Nottingham and Köln
Good stuff, I did think your alloys looked mint :)
I replaced all mine on the W251 last month as they were showing rust, as I said OCD, whilst you are at it, consider getting rid of the locking nut, just a PITA to be fair, there will come a time it breaks or you lose the key
M
MRN1K
Thank you. Much appreciated!
