W221 S350 not starting (doesn’t even try) after service.
D
DSK
CLS 320 CDI, S350 Bluetec
  • #202
T87 stuff done.
Wheel sensors done.
Car has not faulted since.
I have told Nick he can take the car home over the weekend, if it faults, he will have his kit on him there and then. I did tell him to avoid every pot hole.
I’m collecting it on Monday lunch time.
malcolm E53 AMG
I didn’t realise this saga had got to be 11 pages long good luck with it hope they’ve finally found the fault
D
DSK
  • #204
Well I’ve only seen one ‘S350’ no start issue as ‘resolved’ in all my searching of the www.
The rest are all open ended despite similar issues and having ECUs, SAMs, starter motors, EIS, gear selectors etc get replaced by garages and dealers, with the issue ongoing or the thread ends.
We are at the top spot on Google now for an s350 not starting
MB centre do not do courtesy cars, if Alex or Star do then it may be a case driving it down if it happens again.
malcolm E53 AMG
I share your enthusiasm for sorting it especially if it’s a good car and there is always that element of not being beaten half the battle is finding the right Electrical Technician to take it to nowadays
D
DSK
  • #206
A good car is understatement. The service history and maintenance in my ownership is beyond OTT so nothing other than new can compete. Before that is was a genuine 2 owner, low mileage, regularly serviced car with, all the docs to support in detail. I can assure you no other w221 or car will be maintained like my cars.
A 2013 w221 s63 5.5/65 could be a possibility but it’s a bit like an apple never falls far from the tree. I don’t want to have to do all this work on another having learned about their common issues.
I don’t fancy anything new/modern as you all know what I think of new stuff and this example cements when I say the complexity is beyond that of reasonably skilled techs, leaving the owner stranded. My 95 Supra and 98/00 Volvos run like new and have never skipped a beat or had an issue/breakdown, and I know they will out last anything new without a sweat.
D
DSK
  • #208
Car collected.
I took a detour home so I could use it enthusiastically and it performed very well, just like it was before the service, gearbox no longer holding a gear under enthusiast use on upshifts, which it did immediately after the service in November.
I’ll check my dairy but will do some more test drives on Fri/Sun this week but, really need about 2 weeks so I will report back.
D
DSK
  • #209
15/04/2024
Terminal 87 relay changed.
4 x New wheel speed sensors fitted.
Car collected.
20 mile detour home, car performed amazingly like it did before the service. The gearbox did not hold gears under enthusiastic use. The car is as responsive, fast and smooth as it’s was before the service.
17/04/2024
Car started perfectly.
Left it running for 10 minutes before switching it off.
19/04/2024
60 mile test drive.
No issues.
Car performed amazingly in every sense. The effortless and relentless pace, as far round the clock as sir would like in just a jiffy is back. The gearbox did exactly what it should, when it should.
Let’s hope the car starts first time all next week too.
D
DSK
  • #211
15/04/2024
Car collected.
17/04/2024
19/04/2024
60 mile test drive.
No issues.
21/04/2024
60 mile test drive was sublime.
15/04/2024
Car collected.
17/04/2024
19/04/2024
60 mile test drive.
No issues.
21/04/2024
Fingers and toes crossed buddy !
D
DSK
  • #215
15/04/2024
Car collected.
17/04/2024
19/04/2024
60 mile test drive.
No issues.
21/04/2024
22/04/2024
10 mile test drive was sublime.
I never start it and switch it off, so went for a quick run back/forth on the A52.
D
DSK
  • #216
15/04/2024
Car collected.
17/04/2024
19/04/2024
60 mile test drive.
No issues.
21/04/2024
22/04/2024
24/04/2024
Left it running for 20 mins, EML light on, quick drive and it was sublime in every way.
26/04/2024
Drove to MB centre for code read. Car drove sublimely. nox sensor upstream code.
Nick the owner said they cleared and reset the adaption for the NOX sensor just in case it’s to do with the replacement ECU and cloning. He doesn’t want me spending money on sensors if they are not faulty.
All the wood is touched and I’m sure with the number of starts I’ve done now the no crank/no start issue that started this thread is resolved. I’m going to get a good few miles and use in this weekend and next and will write up a summary to conclude this next week.
krsebest
W221 S350 CDI
15/04/2024
Car collected.
17/04/2024
19/04/2024
60 mile test drive.
No issues.
21/04/2024
22/04/2024
24/04/2024
26/04/2024
Thanks very much for the info. Today I did some DIY (never thought I would be doing this myself), and after unscrewing a few bolts, I managed to access the front SAM below the ECU.
When I pulled out the relays one by one, all seemed to look fine, with the exception of the grey T87 relay: one of its connectors is pretty corroded and green. Plus interesting fact: if I take it out and turn the key, it reproduces all the same errors as when the car doesn't start (run flat and esp yellow errors on dash + no coil sign + no start + air compressor not turning on). When I put it back the errors disappeared.
Mercedes spart number: A0025422619
HELLA 4RA00779307. Seems like can be bought from ebay for a tenner.
On the first chart it should be C (Terminal 87 Engine)
D
DSK
  • #218
Great!! Seems like yours is solved too! Thanks for posting a picture of the fuse box!
Out of curiosity why do you have a different part number to what was shown on my receipt?
So glad that the www finally has a solid answer to this blood boiling issue that’s seen many threads started but, never completed! Certainly it will be helpful to the mechanics and owners, where this thread has a resolution to this issue. This will help others not be lead down the path of an EIS, ECU, SAM, gear selector, starter, etc. Furthermore it emphasises the importance to post the resolutions rather than leave threads hanging.
Just to point to out, research shows that T87 is also only applicable to the diesels, again the ones that litter that www without a resolution, unlike the petrol variants which are usually fixed by a starter motor and relay here and there.
malcolm E53 AMG
All this reinforces the case for the adoption of aerospace type connectors which the car industry has talked about but never introduced - being cynical why would they as only the consumer benefits - a pity though most electrical gremlins are due to ingress of water and poor quality of components unfortunately
D
DSK
  • #220
Too much money to be made selling recycled plastic crap on 4 wheels garnished with electrical bs to hide the poor quality, on tick to consumers. Simply why I don’t buy and keep anything modern for myself.
Even Nick at MB Centre said modern new stuff, not just MB, is very ‘thin’ in every way whilst we were talking cars.
www.W140.co.uk&www.r129.co
