julesg007
Hi all,
Got the above issues with the B and would like some pointers to where or how the water or waterever liquid it is is getting there.
From the 2 issues my main concern is the liquid under the battery as I think it is causing me issues with the vehicle. Had to change the battery recently as it really old and was therefore surprised that the replacement had discharged to the point it wouldn’t open the car although somehow I managed to get the car door open! On removing the battery to recharge it I have discovered that there is a liquid under the battery and in a void space beneath the battery tray. I hope you can seen this from the pictures above. I have checked the battery and the casing is fine so I don’t think the battery has leaked or anything like that. In one of the pics you’ll see part of a plastic tube, this is vent tube that was attached to the original battery, has perhaps water got in through that as it has been a bit wet recently after I changed the battery?
With regards to the boot I’ve not noticed this before and we’ve had the vehicle ages although a friend of mine has had the same issue.
Any pointers in where I should be looking and what I should be doing will be gratefully appreciated
Jules
