What Nokia phone fits this cradle on my E320 W211 2004
PaulThomasFarrell
London UK
E220 AMG Night Edition Prem Btec A
I've had the one that was in there nicked and I thought it was a Nokia 6310i (nope) then I ordered a Nokia 3310 (nope) what the hell was the make of the phone that was in that cradle it worked a treat? Any advice welcome. Thanks. Oh and I know the tray needs a clean...I'm on it!
Looks like a 6310 to me...?
5110 perhaps?
5110 perhaps?
I thought 6310i as well initially but thinking it’s not when I zoom in.
Can you unplug the cradle, it might have the model number it takes on it somewhere.
AMGeed
Poole, Dorset
S204 C180K
The 6310i phone is used in the cradle with the curly cable.
I see no cable on that cradle. Is it an UHI connector underneath it?
This is the cradle that a Nokia 6310i fits into along with the part # in the second photo.
The Viseeo MB-3000 also fits this cradle.
I fancy the Viseeo MB 4 unit fits the OP's cradle but I can't be sure.
3788e Motorola? Thinking antenna connection on wrong side for Nokia
Chrishazle
Nr Ashford, Kent
You should be able to disconnect the cradle from the UHI connector - push a button and slide the cradle either forward or back to disconnect it - then you can turn it over, get the part number off the bottom and find out what phone it's for. Equally, once you access the UHI connector you can find out (via comand.co.uk) what else you can put in the cradle's place to bluetooth other phones to it.
PaulThomasFarrell
PaulThomasFarrell
London UK
Thanks all for the informative and helpful responses. I'm popping out now to remove the cradle and get that number off the back. This forum is a Godsend to this wannabe Mercedes owner! I hobble along addressing each issue with invaluable help from here.
Sadly Comrade Khan will shut me down with the ULEZ. Wont be able to find a fix for that other than to walk.
AnthonyUK
Alton, Hants
C240 estate 2002
I might have a hardly used 6310i somewhere. I'll see if I can find it if required.
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
On my cradle same as yours there’s nothing on back of mine.
PaulThomasFarrell
PaulThomasFarrell
London UK
Ladies and Gentlemen and those unsure,(have to be inclusive)
Many thanks for all the chip ins. I have news. I hope this helps other forum members.
For the above mentioned picture I can confirm that it is NOT the Nokia 6310i that fits. It is the ***NOKIA 6100****
Pictures here. Bung any sim into an unlocked 6100 and your beautiful Mercedes Benz E320 CDI Avantgarde will pick it up and make you feel rather posh being able to speak hands free for less than the cost of a steak dinner at Weatherspoons!
Thank you all. You simply do rock.
PaulThomasFarrell
PaulThomasFarrell
London UK
And yes I know my car interior still needs a clean....
Chrishazle
Nr Ashford, Kent
Were you able to remove the cradle from the UHI connector, or is this some form of cradle installation that is not a cradle clipped onto a UHI connector? Maybe a call to comand.co.uk with your VIN would shed light on the installation, as with the VIN they can look up the build sheet for the car, and as they know more about MB ICE/satnav/phone stuff than MB themselves, the conversation could be quite enlightening!!
PaulThomasFarrell
PaulThomasFarrell
London UK
Not this time but I took the cradle from an old car (E320 CDI Avantgarde) and it clipped onto the UHI connector in mine. Thereby allowing me to fit the Nokia 6100. Latest drama is frayed and broken wires in the offside indictor flasher housing.....So bought a soldering iron and will attempt to fix that on Sunday. On we go.
mercmancdi
mercmancdi
Is your cradle same as mine with the
curly cable attached and number
A211 820 1451. On it.
And the Nokia 6100 fits this ok.
Thank you.
PaulThomasFarrell
PaulThomasFarrell
London UK
  • #17
Ah now there’s a thing. No curly cable in view in the tray but perhaps out of sight underneath??? The 6100 fits the tray in my original post pic.
Works a treat. Cheap as chips used to be.
mercmancdi
Chrishazle
Nr Ashford, Kent
OK, so you do have a UHI connector, which means you have multiple options of what to clip onto it. I used to have a Nokia cradle as at that time I had an old Nokia phone, but I now have an iPhone 4 with the matching cradle in the S204. OK, it means I cannot keep my phone in a case if I want to clip it into the cradle when in the car, but when in the car it clips into the cradle and charges, as well as linking in to Comand so steering wheel buttons and hands free works. You could also clip a Viseeo or similar onto the UHI so other bluetooth phones will connect - if any of this interests you, give comand.co.uk a call!
mercmancdi
View attachment 48373 View attachment 48374
Do you know ,,,,,,Would viseeo mb4 fit into cradle in photo above with Curley cable.
