What Sl should I Buy
Chrishazle
Nr Ashford, Kent
COckpit MANagament - can't remember what the D is for.
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
I thought we had decided on an R230 SL350 without ABC suspension , but with full Comand. ;)
OP seems to have disappeared. Meanwhile, we have decided on SLK55, problem sorted. :)
Democracy doesn't work...:p
R172 350 I'd recommend or a R231 SL350
SL63 Mark
The South
R231 SL63 AMG
Yes, but then JBell found a 55 in budget, and we went off down that route. You know it makes sense.
I would love one to run around in, values can only go one way, (up).
Maybe if the OP returns, he can give us a steer.
All good apart from the below from the OP…;)
I do not have deep pockets for repairs.
NJS5
Why not an R230 please? For his figures he could get a reasonable R230, or possibly a high mileage, low spec. R231 although I confess I haven't seen one for £14k or less.
NJSS
NJSS
Because of…
R230’s can be expensive to keep going - SBC braking and swimming pools in the boot leading to serious water damage.
SL63 Mark
The South
R231 SL63 AMG
NJSS
I think a 231 would be pushing the budget a bit ? Lovely cars, though.
peterws1957
Lancashire
Because of…
As long as they're not used as a daily and you choose carefully, they don't need to be expensive. Ours is garaged though and doesn't get rained on cos its a wimp.
00slk
Cambridgeshire UK
I used my r230 SL55 as my daily for nearly 4 years added 35,000 odd miles to her, not much difference in cost to the 2 r230 500's we had.
SLK, buy and forget, you don't even need pockets to run these, had 320, 350 and the current 250. Cheap, economical and reliable ;)
Flyinspanner
Ruislip
I think now that I’d rather have one without Comand.
Its old tech (hardware and software).
The optic system makes it hard to upgrade.
id rather have standard Audio - much easier to swap to a modern headunit which will have functionality streets ahead.
00slk
Cambridgeshire UK
I think our SLK is Audio 20 as it is Pilot Sat Nav?
