What went in this hole in my M113 V8 CLK Exhaust ?
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Exhaust suddenly starts blowing and i found this hole ,something was here a blanking plug perhaps ? It doesnt look threaded but hard to see inside
was it a facility for a sensor on american / export models and was blanked off for uk ?
engine is running fine no faults on the dash computer no loose wires or a sensor hanging loose
best way to restore it / blank it
mercedes blanking plug ???
not sure if welder can get in there
bolt and washer glued in with gun gum
Any further suggestions welcome
Boyd
ajlsl600
france
Assuming nothin meant to be in there. Measure it find nearest tap size. Tap it fit same thread bolt with copper washer and coppers lip. In case bolt needs come out again
T
tjamesbo
yes someone on the other forum had the same happen says hole was for a lambda sensor on US spec Cars they had a cap welded on but i like your idea i'll look to check i can get a tap in there thanks
From memory M18x1.5.
Quick solution is get a bolt. Cut a slot in the thread (lengthwise) and tighten up. If it still leaks find someone friendly with a welder. Two minutes later it'll never trouble you again.
star
Reading
Smart + others :)
Looks like the bolt hole for the heat shield that’s missing. I’d be looking at the joint being the 44AB1B2F-B984-410A-96C1-412A7B4D6BFD.png problem.
ajlsl600
france
Ah we on same page often de case here I even have the locals doing it instead of ussual choice of close fitting(not always) and various size hammer!!!
ajlsl600
france
I use 1mm cutting disc to cut 2 slots along bolt length at 180 degrees if fitting not very hard and one takes time I find this usually does job esp if bolt decent quality
Yep pretty much my method too though usually I use a Dremel so finer slot. I guess I'm more used to smaller bolts than you.
ajlsl600
france
Somat like that.....
www.ckinsurance.co.uk
