Whats reasonable oil pressure?
stuuey
New Registration
Hope someone could clear up a query of mine, looking at a 300e with 166000 on the clock, oil press needle 1 at idle, up to approx 2 1/4 when driving, never saw it reach 3? Does look like it could do with an oil change though!
Also noticed at a steady idle, gauge fluctuates between 1 and 1.5 though engine revs remain constant. Any ideas appreciated.
iamamanc
Sounds like the big end is on it's way out, but I could be wrong
An oil change could help, it could be a sender out of spec, oil filter clogged
hmang
what is the book oil press figure and test method ?
hot or cold test?
is correct oil in engine?
what oil press gauge are you using and is it accurate?
Tel: 020 8863 9233
