Where to place weights on wheel balancing
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
sorry if this has been done .
Got front wheels balanced today and
only noticed when I came home the weights are on inside of rim but out near front face. Not very pretty looking , can these not be placed
Near back of rim where you can’t notice them.
bembo449
gainsborough , lincolnshire
the weights need to as close to each bead of the alloy as possible so unfortunately your stuck with them
You can on occasion get a tyre fitter to fit weights behind spokes but you'll need more weights and it's a ball a he for the fitter to get right.
mercmancdi
mercmancdi
There are behind spokes but very visible , even if they were a few inches further back.
bembo449
they are on my 216 and 221 pal , its unsightly but if that where the machine says they need extra weight to balance the wheel out then that where they must go but by all means take it back and see if they can get it to balance with the weights closer to the centre of the alloy
A.J.
Norwich. UK
I had a new pair of rear tyres fitted recently and I asked the fitter to put them on the inside or back of the rims which he happily did. The wheels were balanced perfectly. Wheel weights out of sight. :)
L John
W204 C350 Petrol Elegance
Sounds like a spot on job.
Weights are necessary unfortunately, best you can do is paint them to be a close match to the colour of the alloy wheel.
flowrider
SL500 (R230)
You can ask the fitter to put the weights at the back or ask for them to be positioned directly behind a spoke to hide them. As said it does take more time to get it right but looks so much better.
mercmancdi
mercmancdi
I think where they were needed it would be hard to get behind spoke as they are only 5 spoke wheels.
that would have worked ok on a multi
Spoke.
flowrider
SL500 (R230)
Spoke.
You just need heavier weights. I guess success depends on how badly out of balance the wheels are to start with.
mercmancdi
mercmancdi
Yes it held 5 on outside 2 at rear.
Pity it couldn’t been done 2 1/2 to 1
But I guess it doesn’t work like that
Correct it doesn't. Your correcting weight mismatch on the diametrically opposite side of the wheel not inside to outside.
mercmancdi
mercmancdi
Thanks I think I am bit fussy , any how now I have had to order 4 new brake disc and pads , Grub screw in disc are butchered
So looks like a drill out for one of them.
Sometimes judicious use of a hammer and cold chisel can yield good results.
Failing that since you're replacing the disc a Dremel cutting tool or angle grinder can cut a slot across the head for a screwdriver.
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
That's what I did
An impact wrench can be very good for removing the grub screws
mercmancdi
mercmancdi
Small punch and hamer removed it sad to say had no new one to replace it ,
So that’s on a to do list.
mercmancdi
mercmancdi
  • #20
Just to say why ,when you buy a pair
of vented disc are they not handed
ie vents face into air flow on both disc
Or is it only on the very most expensive they come like that.
