Windows fogging up massively, despite dry interior
AndymT
C220d bluetec 2015
Hello, regularly experiencing the above problem on my 2015 C220 Bluetec and I've seen reference to blocked windscreen drains on older, different MB models. Can anyone point me towards where to look on my model - or suggest other remedies - please?
Ken_R
Worcestershire, UK
W203 2006 C230 Estate
Also check your Pollen filter. If that has got wet it will cause the problem as described.
Do you have your Aircon on to clear it . Is there water in the boot where the spare tyre is ?
GlosRichCLK
Gloucestershire
2019 W177 A180 SE auto, 2012 W212 E350 CDi Sport saloon, 2001 CLK 230 K Cabriolet A208
Another vote for pollen filter, easy to change.
Also only run your AC on auto and let it do its thang....
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
From my experience... confirming much of the above... a car with aircon will only fog up if...
Aircon is off. Pollen filter is blocked. Heating set to recirculate. Screen vents not on. Loads of water that shouldn't be in the car.
flowrider
SL500 (R230)
Check under the carpets for any moisture, try leaving the car in the sun with the windows open and see if it improves, if we getting any more sun.
A
AndymT
C220d bluetec 2015
Thanks for the ideas all. Definately not moisture in the car or boot, screen vents or recirculate switch on. We noticed this problem from the first few weeks of ownership. It's been MB serviced from new but I'll check the pollen filter in case they missed that. As for the aircon idea, maybe I'm being a bit thick but how does that work in the winter months when misting up is a real issue and you want warm air in the car, not freezing?
flowrider
SL500 (R230)
you just turn the temp dial up for warm air.
Droverunner
West Cambridgeshire
I have noticed on cars with aircon that if you mistakenly switch off the aircon in the autumn/winter months at the start of a journey the screen can mist very quickly. But otherwise if you are using the climate properly by leaving it to auto then there should be no mist apart from exceptional winter mornings when you might need to push the clear screen boost for a minute when first starting.
Re how the aircon works in the winter... Better on than off as it has a dryer in the system to remove moisture... better to have cooler dry air than warm moist air which is a classic for dropping out its moisture onto a cold screen.
David Richardson
Plymouth
W176 Blue Eff CY Sport CDI & C Class Coupe 2002 220CDI
You could run a 240v home dehumidifier in the car for a day & you'll be surprised just how much water
it collects from the air inside your car
Leave your Aircon on all the time ,otherwise the Aircon compressor seals can dry out . Regulate the cars temperature by turning to hot or cold as normal . Aircon dries damp air wether hot or cold .
oigle
members.optusnet.com.au
If the weather is rainy and cold, it is good to use recirc setting when starting up. Leave it on recirc for a few minutes at least before switching. Just gives the system a better chance of getting rid of the moisture without a new load coming in all the time.
Ian.
John Laidlaw
Wirral
Land Rover Discovery 4
www.W140.co.uk&www.r129.co
