Windows seal replacement
Hibbo
East Scotchland
Hello to everyone,
Has anyone replaced a (exterior) window sealing rail on a w123 before? I've got a new one for the driver's door on my 300D, but am not sure how simple it will be to change.
Can I simply pull the old one out and put the new one in? Or do I need to take the door apart and drop the glass out of the way?
Thanks in advance.
Hibbo
Hibbo
East Scotchland
turnipsock
Port of Menteith
I'm sure mine fell out when I had the window out. That was a 124 though.
I might have a go at replacing mine, they seem to be turning green.
I used to have some thin strips of metal going to a U at the end,that I could slide down between the glass and the door and pull the fixing clips up to the edge of the door.
malcolm
turnipsock said:
I think I used the things that I bought to take out the instrument pod.
Is that what you call economical or genius, I will settle on the later :cool:
Malcolm
TimN
Hertfordshire
Use a wooden spatchula and prize it upwards. I'm sure that it must be possible to replace the rubber part alone if you can get the right section from a specialist supplier. It can only be crimped in position or stapled.
