Windows trim care needed
Linuus
crawley
w210 wagon
Hi guys so I’m wondering if there is any solution to the below pictures. The window trim has some kind of stain or decolorisation, I think this is due to something corrosive of very front some just pored. When I bought the car, this was already in place.
lasa
E Class estate E212/ 2012/E220
Whatever it is looks to me to be lying on the surface, first I would try very hot water on a piece of towel, if that does not work I would try Autosol applied lightly.
Try electrical contact cleaner sprayed on a cloth first , it worked wonders on my Clk trims .
Linuus
Linuus
crawley
w210 wagon
It’s not at the surface, but will give a try with metal polisher. Ps: didn’t work with any cleaning product
L John
W204 C350 Petrol Elegance
You cant lose anything by trying but I only see 3 options.
1. Replace
2. Wrap
3. Spray
brandwooddixon
Wolverhampton
S63 Coupe 2014
I can't imagine what has done that and not damaged the paintwork as well.
Could the door have been resprayed?
If its actually etched into the trim e.g. you can feel a dip at each mark then I'm with LJohn, although my preference would be to replace them.
Have you tried some polish or T-Cut on a small area to see if it makes any difference?
Morethanpolish
Stamford
CLK 200 Kompressor
This product will save the day:
Hindsight Aluminium Trim Restorer
Tired of dull, blotchy trim around the windows of your Audi, Mercedes, BMW and many other cars ? The roof bars on estates also show the same problem, but Hindsight has it covered... Our simple 2 stage kit contains sufficient product to polish up and protect these areas which have been hitherto almost impossible to correct. The best bit is, its easily done by hand and doesnt take very long either.
The Kit contains 2 pots of product - 15ml each of Polish and Protective Wax with Teflon, plus cloth and 2 quality applicators.
http://www.morethanpolish.com/hindsight.asp
Linuus
Linuus
crawley
w210 wagon
I can’t feels any dip into the paint or trim. I will try metal polish next day off.
Morethanpolish
Stamford
CLK 200 Kompressor
Clay bar wont work as that only deals with things stuck on the surface, you need to penetrate the surface to restore this material. That's why polish wont either.
ioweddie
Winford Isle of Wight
W205 AMG Sport Line Premier Plus Estate C220d
Did you soak some tissue and leave it on for about 10 minutes?
Linuus
Linuus
crawley
w210 wagon
No, that’s I haven’t done. Monday will try, car polish, metal polish. And white vinagre and see if any will do any difference. If not.. I will replace it. I might find on eBay or junkyard some trims :)
AnthonyUK
Alton, Hants
C240 estate 2002
Woah. Are these supposed to be chrome/silver?
Mine are a gunmetal colour which I quite like but never thought they had discoloured.
Be gentle, I've not had the car that long.
