Wiper Blade Change
JCP
Doncaster
2017 S350 L AMG Line
I've bought a pair of wiper blades from an MB dealer for my 2017 S Class, to replace the original blades.
Does anyone have the instructions etcthat I can use when replacing the blades?
I can see the blades slide off the arms and there are wiring and hose connectors withing the blade fittings.
What I'm looking for is the correct way to complete the swap without damaging any part of the car/blades/wiring and the hose connectors.
The chassis number (if it helps) is WDD2221322A306961
Thanks in advance of your help.
Jim
normally just operate wipers till vertical, switch off, pull arms forward, press clips, slip blade out and reverse.
Perhaps post a pic of the fitting. Unless the new S class is loaded on the wiper with gizmos
JCP
JCP
Doncaster
The wipers has what appear to be two water connections and power connections for the heating/frost protection.
If someone has the instructions from WIS, that would be great.
JCP
JCP
Doncaster
Mioba,
Many thanks for this - it looks easier than I was expecting.
tbf its exactly as i said in my first post and to find the video was 2 seconds on google.....
JCP
JCP
Doncaster
Mioba,
Thanks for this and I've just changed both blades and was as easy as the video showed - spot on.
I appreciate your assistance.
Glad you are sorted.
As a side cant imagine those blades being cheap, crazy design by merc.
