wont rev past 4500 rpm
dellbagz666
exmouth
ive just purchased a merc E200 on an M plate but the little suckers rev limiter cuts in at 4500 rpm. any ideas?:evil:
Hi & Welcome,
In P or D?
D
dellbagz666
exmouth
Hi And Thankyou. Im Completly New To Mercedes. Sorry I Dont Understand
Will it only rev to 4,500 in Park, Neutral or Drive. As there is a rev limiter in Park & Neutral. I am of course assuming you have an automatic. :cool:
mlc
South Manchester
2001 S320, 2003 SLK230, 1972 350SL
so just to clarify. start off in 1st, drive off and stay in 1st, and it does say 20 mph foot on the floor and stuck at 4500 rpm?
D
dellbagz666
exmouth
it just wont go past 4500 rpm in nuetral, 1st, 2nd and so on.
D
dellbagz666
exmouth
i thought at 1st it was a limiter that only kicks in nuetral but when i drove it home the limiter kicked in at 4500 rpm in every gear. ive been advised it may be the air flow sensor?
roofless
w124 e220 estate
hi i had the same fault in the past with my 300te with no joy till on the way home from work i had a burning smell then it stoped on me .the prob was the fuel pump relay so i did a temp repair to make the pump run to get home on the way it drove without fault so i fitted a new relay and the prob was solved for good
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Read something about this on another forum re; w202s may still apply to your car depending on injection system fitted.
They had very similar symptons as you and it proved to be the main Engine ECU.
Lets hope i,m wrong, bit expensive to replace there are places that will repair yours a bit cheaper than buying a new one.
