We concluded the obvious in that previous case - an internal fault in the cluster.
If you look at the display from oblique angles you will see the yellow is far less pronounced, and the display appears more normal.
The guy who owned the car did not want to pay for a new cluster, understandably, and was convinced it was because his service interval had been exceeded - which was clearly not the case.
He later reported that it had 'fixed itself' and gone back to normal, that was shortly before I left that job to start the 'Alex Crow' empire, so no idea of the long term situation.
I would suggest a phone call to ACTronics if the symptoms persist.
