E
echo200
Vehicle: W203 C200K, petrol, '55' plate.
Other than the warning lamp, the car is running normally. There are no other obvious symptoms, such as engine misfire.
The manual suggests three possible malfunctions, viz.
1. Fuel injection system
2. Exhaust system
3. Ignition system
If it turns out to be the exhaust system, presumably I could be looking at a broken catalytic converter in which case any advice on sourcing a replacement (+ cost of fitting) would be appreciated.
2. Exhaust system
3. Ignition system
