Geeves
- Jun 28, 2009
- Location
- Cape Town, South Africa
- 2003 E270 Avantgarde
Hi guys
My apologies for bringing this often discussed issue up again once again, but I have spent hours trawling the net and searching this forum for an answer, but feel more confused than ever before. So I am just going to ask out straight - is there anyone on this forum that might be able to tell me whether I should worry about the valeo radiator issue?
Details are as follows:
W211
E270
2003
52,000 miles
Pampered
Research seem to indicate that both my engine (647961), gearbox (722640) and build date (30/09/03) should make me worry, but not my VIN (2110162A396544). Is that right? I have also tried to see if I can identify my radiator, but I was not able to. I was, however, able to identify the small cooler in front of the main radiator as a Behr. Should I worry?????
I do, however, have one or two other issues I really hope someone will be able to help with:
- Slight vibration on the steering wheel accampanied with light rumble when braking lightly from higher speeds (i.e. 60+ mph). Brake discs and pads are basically brand new (less than 10,000 miles). Torque struts? Control arm bushings?
- Clunk/rattle from front when going over bumps. Linked to above - suspension? Or can it be engine mounts?
- Strange whining/moaning sound. Not unlike a power steering pump that is on the way out or low on fluid. But it is not the power steering pump as sound does not change much with turning of steering and it feels fine. Linked to engine revs sound changes. Seem to be present whether in gear or not. Comes and goes, does not seem to have a particular pattern, but usually more audible at lower speed (i.e. below 50 mph) when cruising or coming off the throttle. A buzziness/grittiness/light vibration can be felt through the steering wheel at the same time when sound is loud for a second or two (which happens every once in a while). Engine mounts? A defective pulley or bearing?
My dealer has been unsatisfactory so far...
Much appreciated!
G
W211
E270
2003
52,000 miles
Pampered
Much appreciated!
G
