Yet another AdBlue error thread…
2019 A180d - W177 with 1,461cc OM608 engine
Just covered 9,000 miles and AdBlue system advises it can’t read the AdBlue level, this gives a 500 mile range before switching to reduced performance operation. Mobilo have been out and can’t reset it, plenty of AdBlue in the tank, so it’s booked in on Wednesday.
I’m expecting the main dealer to advise they’ve never seen this issue before… :rolleyes:
Software update? Sensor replacement? Pump failed? What’s the forum’s ideas?
Cole@MBS
www.mbssouthampton.co.uk
We see this a lot Russ, could be anything from Nox sensors,, ad,blue delivery pump, ad,blue tank leak, software etc etc, did mr mobilo have any fault codes???
  • Moderator
None that I know of as I wasn’t present when they attended. Yellow engine warning light on permanent and the AdBlue warning comes up once you’ve driven a few miles.
I‘ll try to find out what the dealer finds on Wednesday
I take it it’s all on warranty whatever the fault(s) ?
mioba
Nottingham and Köln
Good lord. What a disaster these ad blue systems.
The majority of posts are always replacing the entire tank as the senders are part of the tank.
That said, thats on slightly older cars, so no jumping the gun till the codes are read and you have been in atleast 3 times in the next month to get it all sorted.
Glad you are still in warranty...(assuming)
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
After nearly 4 years decided to sell my 2014 e350 bluetec due to all this nonsense and luckily had a fast easy sale last week, petrol next and time to relax and stop worrying about adblue, pumps methinks. good luck.
malcolm E53 AMG
The only problem is that the few S213 petrol cars available with larger engines E43/53 are holding their residual value due to high demand - guess I’ll be waiting a while longer
bladecrazy
bolton
same here , would like a 3ltr v6 petrol with 5 seats.
  • Moderator
Monday and Tuesday this week, no yellow engine warning light... Probably because it knew it was going to the garage... :rolleyes:
The car has stayed in overnight as they need to get a replacement metering valve for the AdBlue - more updates as they're available ;)
  • Moderator
Ad blue meter valve and control box replaced - MB Dealer advised the car has already had the issue previously…
Car is back
Car is back
Not great that this is the second time in a short period. Suggests a fundamental issue somewhere in the design.
  • Moderator
Agreed, it only has 9K miles on… I suspect that the AdBlue has crystallised due to sitting around as I expect it’s on its original fill…
  • Moderator
My friends V8 4.4 Range Rover has just gone into reduced performance mode… “emissions system heater failure” - which is the AdBlue… another sensor is reporting as faulty as well.
curious
Only the Vito left! W639/1 OM646
How long before someone manages to hack it out of the software and switch it back on for the MOT?
  • Moderator
  • #17
Thing is they'll work perfectly well without the AdBlue system... problem is that's slightly worse than a hanging offence...
  • Moderator
  • #18
Guess what - it's back at Mercedes with the engine warning light on and an AdBlue System fault -Well, mark me surprised (not)... :rolleyes:
MB now saying they've changed everything and no idea what's wrong so have contacted MB Technical for a fix...
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
I wonder if there are any sensors in the AdBlue systems that would detect tap water if it were used in the tank in place of the AdBlue fluid that should be used, as it appears that apart from mechanical failure, the crystallisation of the AdBlue product is a common cause of failure?
mioba
Nottingham and Köln
Hopefully MB tech have the answer having seen this before and you are back on the road soon.
