MrShades
- Aug 11, 2022
- 1992 Mercedes 300 SL, R129 - Mercedes SL, R230 - Corvette StingRay Sport Coupe
First i will need to say that i was going to check the wiper/combi/N10 relay (part number A 129 820 1026) on my 1992 300 SL and when i took off the connector off of the relay all of the wires came loose on the 21 pin connector (See the picture attached below) I frepaired this for about a month ago. I am saying this just in case the power window problem can have anything to do with the fact that i put all of the wires (18 wires on my car) back on in the 21 pin connector.
I found out where each wire is supposed to sit on the 21 pin connector here on this forum in a thread posted by davidsl500 where he wrirtes where everyone of the 21 wires is placed So a big thanks to davidsl500 for the post
But now i have another problem and that is the right hand side power window. The left hand side power window is working fine
I have checked the fuses in the boot/trunk and nothing wrong with the fuses
The reason i ask if the any here knows if the power windows is connected in any way to the wiper/combi/N10 relay is because the power window problems started about 3 weeks after i had fixed the wires back on to the connector for the relay.
I have to add that i looked at a wiring diagram for the power windows and to me it looks like there is no connection between the power windos and the wiper/combi/N10 relay
I checked absolute everyting after i had sorted out the wires and put the relay back on and everything was working fine.
So i thought that it might be that the window mechanism that had come loose inside the door so late last evening i took the inner door panel off but nothing was broken .
So i turned on the ignition and tried the right hand side power window and it worked perfect.
Since this was late last evening and it started to get dark outside i decided to put the door panel back on today so i left the window 70 percent closed.
The last thing i did last evening was to charge the battery so i did take off the negative battery cable and since the battery was being charged overnight.
So today i put the door panel back on and when i was connecting the negative battery cable to the battery the right side power window went into fully open position as soon as the negative battery cable touched the negative pole on the battery.
How can this happen when nobody i pressing the open/close window switch?
Another thing is that when i put the ignition on position i can hear some clicking sound coming from the right side door and that without me pushing the switch for the power window.
Any here on the forum have any idea what may cause this?
