1994 E320 problem
Ash145
Hi all, I need to move my much loved bit not well looked after E320, I haven't started her for a over a year and tried at the weekend with no joy :(. Tried booster pack which turns over no problem but can't hear the fuel pump vacume kick in, I think its that as I'm sure I used to hear something make a noise when I turnrd the key. Problem is I need to move the car and it's in Park. Is there any way to get it into neutral so I can potentially tow the car.
robparker
Taunton
with the key turned and brake depressed is should go into neutral. Could just be the fuel pump relay, I think its a little green fellow on that model near the battery.
grober
Scotland
W204 C200cdi estate
Battery or booster supply at 12v[important]. as above Ignition on-- foot on brake pedal---move lever to neutral
A
Ash145
Fuel Relay?
Is there any way of checking the feul pump relay?. My E320 1994 will start by simply manually pouring fuel into the inlet manifold :shock: but not any other way. I can hear the pump vacume kick in when I turn the key but doesn't appear to be any fuel in the fule lines. Could it be the pump or the relay??..
