1994 E320 Re-start problem
Status
Not open for further replies.
sulkande
Couple of times I have had problems starting the engine. Pecularly it only happened when I attempted to start it after the car had been already runing for a while and then stopped (shutting off the engine) for a short time (say minute or two) . After waiting for couple of minutes and then trying to start it, the engine starts normally.
Is this some timing lock issue?. Should I be seeing a mechanic immediately or I can go on for some time?.
kid-jensen
Epsom Downs, Surrey
Ml320CDI 2007
If you can get it to start by jumping a wire straight to the positive terminal of the battery, chances are the starter solonoid is getting sticky when hot.
Cure could just involve cleaning the terminations, replacement, or fitting a shorting relay.
Rog_E
Cambridgeshire
Do you mean that the engine turns over but doesn't start?
Or it doesn't turn over.
If the latter then this could be because you didn't turn the key fully anti-clockwise before trying to start again.
Or it could be the gear selector position switch - mine is intermittent and I often have to move from 'P' to 'D' before I can start the car!
Neilc
West Sussex
1972 300 SEL 6.3
Could also be a failing fuel accumulator.
Cheers,
Neil
87 190E
89 190 Sport Evolution
Status
