1996 c280 sport with high tickover
rob the painter
coalville, leicestershire
Greetings all. I was just wondering if anyone can help me.
My c280 straight six ticks over at around 1500- 1800 rpm when the engine is warm. First thing in the morning when cold, the tickover is under 1000 rpm as it should be under normal conditions.
I removed the throttle body, cleaned it with carb cleaner, inspected it (I noticed an adjustable 'stop' inside the mechanism so maybe it can be re- caliburated?) and built it back up using grease on the original gasket as it looked serviceable. I also replaced the MAF meter.
After doing this the car went into limp home mode. I took it to the garage for a scan but it seemed to cure itself. It was MOT'd, passed, but played up again reversing off the ramp. The mechanic ran a fault code read but it gave confusing readings. He also said there was low voltage at the ECU. It now drives fine as you would expect, save the high tickover.
I have a feeling it may be the coolant temperature sensor, as there is a smell of fuel, suggesting it may be running rich. Sadly I can't seem to find it. I can only see the coolant sensor (4 pin plug) which, when removed with the engine running, only disconnects the guage (so I assume thats not the ecu sensor).
I would be grateful if anyone can offer any advice. It would be a pleasure to drive if it would run right.
Kind regards, Rob.
R
rob the painter
  • #2
Touch wood,I think she's cured. There is a relay near the ecu that had a loose coil which was arcing out on the relay body. One careful blob of solder later and she ticks over like it should.
www.W140.co.uk&www.r129.co
