2005 CLS 500 transmission lines
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
My Indie wants to replace the transmission lines that connect to the rad at the front...He has told me he needs to take off the front bumper to do it and that i may need a new rad as well if the connector is seized.
Has any one any idea if this is something i can do myself or is it really that difficult? has anyone got a procedure breakdown please?
Arzaam
Pakistan
W203 2002 c180
are the lines leaking? and yes the radiator may need to come off if there is not enough room, sometimes the connector seizes and breaks when opening but shouldn't happen if careful, I am no expert but thats my opinion, maybe someone else here can also give an input
star
Reading
Smart + others :)
It's a fiddly job, easier with rad pack out. They are just a ouch and snap in firing and can corrode badly.
M
matteb63
Abergavenny Wales
Yes the lines are leaking.
And if I can replace them without removing the front bumper even better..
M
matteb63
Abergavenny Wales
has anyone got a diagram that will show me the parts i need to order...there are two lines at the bottom back of radiator that appear to be bolted there and have union joints from which they go up to the rad..i guess i need part numbers our names to order them in but haven't been able to work out what they are as yet?
Arzaam
Pakistan
W203 2002 c180
does this diagram help? you can tell me the item number form it that you require and I can let you know the part number and name. B50600000066.090923-2.png
Arzaam
Pakistan
W203 2002 c180
discard the M156 pic on the right as yours is the M113 motor I believe
star
Reading
Smart + others :)
Omg I hate predictive txt. They are just a push fit, and the fitting can corrode in the rad.
M
matteb63
Abergavenny Wales
so managed to get part numbers 10 and 20 from mercedes newport for £54using the diagram above..great help and will attempt fitting tomorrow..i will release the rad and hopefully that will give me enough access to remove the lines without damaging their sockets.
Steve@Avantgarde
Bristol/Somerset
I always take the bumpers off, it doesnt take long and I hate struggling.
I find you try and short cut by not taking something off, you end up spending just as much time struggling in a tight space. Stuff that.
M
matteb63
Abergavenny Wales
how do you take the bumper off is there a step by step procedure i can follow?
Hopefully this will help.
  • 219 front bumper.pdf
M
matteb63
Abergavenny Wales
bumper came off easily and i managed to change lines although the top line was almost welded in and required delicate manipulation to remove without damage....
Changed the filter and cleaned sump....filled with 6 litres of transmission fluid. Started it up but no drive in any gear....wondering if i crossed lines at bottom of rad but would this make a difference and is it possible that i over filled it.I was unable to find a drain hole on the torque converter so assume it dosent have one. there is a fill tube at the back of the engine.
M
matteb63
Abergavenny Wales
does this diagram help? you can tell me the item number form it that you require and I can let you know the part number and name. View attachment 38900
This diagram isn't appearing to show which Radiator end tube goes to which line..it appears to suggest that it dosent matter.
Parts changed where number 10 and 20
M
matteb63
Abergavenny Wales
the lines attach to the transmission on opposite sides which isn't obvious from the diagram and there are no banjo fittings at transmission..i currently have the lines hooked up with the lower radiator connector running to what appears to be lowest union with transmission..passenger side
star
Reading
Smart + others :)
Did you fit the filter correctly and it hasn't dropped. Why fill with 6ltrs oil if you didn't drain tc?
M
matteb63
Abergavenny Wales
  • #17
Wow how stupid do i feel!! ok so i filled the transmission with nothing...just added 6 litres of expensive transmission fluid through the oil filler at the back of engine ....guess i have too fill it from the drain hole. I'm assuming that when it overflows from the drain hole its full?
star
Reading
Smart + others :)
A little knowledge is dangerous and could have been costly if your engine had run away because of overfill of a gallon. As we now know it's a 7speed, it's filled from under the car. Did you leave the pedestool attached to sump?
M
matteb63
Abergavenny Wales
  • #19
Yes pedistool is still attached see
Steve@Avantgarde
Bristol/Somerset
I have seen this done so many times its frightening. Best be draining the engine oil out double quick time as well.
The level is set based on temperature and flow from the sump bung. That is why the pedastool is there. It is filled from the sump bung yes. The oil level is set with the transmission no more that 50'c
www.ckinsurance.co.uk
