-AJC-
- May 14, 2017
- Location
- West Sussex, UK
- 2006 ML 320 CDI W164
I have just bought a 2006 ML 320 CDI.
The car has a number of loose electrical connectors in the engine bay which I'm trying to establish what they're for? Can anyone help?
1. The first is this connector that was in the front right wheel arch but I have pulled the cable back into the engine bay.
The only number anywhere on it is F8. The two wires are brown/white stripe and green/white stripe.
2. This connector is in the front right area near the right front headlights and Airmatic compressor. The wires are coloured yellow/blue stripe and brown. It comes off a taped wiring loom running to the front right bumper area and must connect to something in that area.
It's almost impossible to see the 10 digit number is the recess but it could be 163 545 2323.
3. The last connector is to the side of the cabin air intake. It is taped to the loom that feeds the heated washer jets but isn't long enough to reach into the bonnet recess. It has red/white stripe, brown and yellow/white stripe wires attached.
It could reach under the front scuttle panel but hopefully someone will identify what it's for?
