Marian Ciulei
- Nov 18, 2018
- ML320 CDI W164
My ML320 CDI W164 from 2007 3.0L CDI-V6 4Matic (642.940) has similar code errors and after I changed inlet port shutoff motor still have the codes from below :
2530 Check component M55 (Inlet port shutoff motor) . Short circuit to ground
2527 Check component Y27/9 (Left EGR Positioner) . Signal line is interrupted.
3053 Check component B2/7b1 (Intake air temperature sensor) . . CAN signal faulty
3052 Check component B2/6b1 (Intake air temperature sensor) . CAN signal faulty
2627 Mass air flow sensor
2603 Check component B2/7 (Right hot film mass air flow sensor) . The air mass is too small
2602 Check component B2/6 (Left hot film mass air flow sensor) . The air mass is too small
Antilock Brakes
6001 The supply voltage of the control unit is too low (under voltage)
Can anyone help me with this?
Antilock Brakes
