2008 S320 cdi Weird Radio Issue
Xflow
Chesterfield
W221/2008/320cdi
Hello
I'm new to the forum and MB so please be kind :)
I was hoping someone could help
I have purchased a 2008 S320Cdi all was well for a couple of months then the Radio wouldn't work in the sense that is makes a pulsing sound of the station its on..
after either a few miles or even many miles it comes on and is fine for the rest of the journey.
Sometimes it just comes on and works Just fine it does it when its cold weather, warm weather raining dry or night or day
It's a real lottery if it works or not its about 50/50 sometimes it never comes on for an hour but come on at next start up an hour later.. It's so confusing
It stops the voice on the sat nav and the CD player
I have trawled the web and Amps seem to be an issue..?
I am open to any suggestions or ideas
Kind Regards Ian
X
Xflow
Chesterfield
W221/2008/320cdi
Thanks for the feedback
I'm sorry it's difficult to follow I'll try and simplify it
Its not harmon kardon and its a W221 S320 cdi with singe disc CD
So Half the time I start the car the Radio comes on as normal :D
The other Half of the time you can here the radio station in 1 second Pulses every 3 or 4 seconds... :(
If it comes on as normal it stops on until the car is turned off :D
If it comes on with the pulsing issue it does this for anything from 2 mins to to an hour however a couple of times it has not come on just pulses all the time (3hrs)
It effects the radio, sat nav, and cd player which also pulses if selected
There is nothing I can identify that causes the issue I've tried it with all sorts switched on and off
I hope this helps clarify the issue.
Any Suggestions Welcome
Thanks Ian
Botus
S500/2010/500
if its on all sources sounds like the amp?
the Harmon kardon amp frequently plays up, usually very shortly after starting up the car.
what sort of mileage? there's a cooling fan inside which plays up quite often. (I believe not related to the fault above). Not had mine apart but I think it might be something one could swap out for a PC fan or an ebay job.
try and get codes read see if it points you in a certain direction
X
Xflow
Chesterfield
W221/2008/320cdi
Hi Thanks for that Botus, I'll try and get the Codes Read
It's not a Harmon kardon
It can come back on after 1 mile up to 30 miles and anywhere in-between
It almost seems like a loose connection, but it never goes off once it's on
It's so strange.
Botus
S500/2010/500
does it do the same on sat nav or with a CD?
the antenna can have issues which wouldn't affect the cd player
the amp affects everything
fibre optics should take out other features
X
Xflow
Chesterfield
W221/2008/320cdi
Yes same on CD & Sat Nav
Could it be the auxiliary battery not holding charge
That would explain it coming on at different times after start up?
Botus
S500/2010/500
so its not the radio antenna then...
re the other points, I was going to say no, but then merc eclectics have a mind of their own and low battery voltage sends and already "interesting system" in to a tail spin of unfathomable proportions
AGM batteries do get dry inside and then don't hold much of a charge, spend lots of money on a new one, or "top it up very slightly" and charge it up fully +24 hrs, then get some one to see if anything shows up in a diagnostic check
