2500 sprinter engine dies at 2100 rpm
Tim belcher
2005 sprinter 2500
Van initially had hesitation when you accelerated then turbo stopped working weeks later
After shut down turbo worked
Changed turbo then Engine shuts down at 2100 RPM tried new computer sensors everywhere replaced injectors you name it I am stumped
T
Tim belcher
2005 sprinter 2500
Well lets start with the basics and eliminate the guesswork, what fault codes are stored?
Hi and low fuel pressure on rail
Just wondering if polarity on crank sensor has changed
Steve@Avantgarde
Bristol/Somerset
Thats no help, put the actual fault codes up, not an abbreviation from your code reader.
What engine is in this sprinter? 2.2 OM646? or 3.0 V6 OM642??]
Nothing to do with the crank sensor. Stop guessing and provide the correct information.
Fault - Information - Diagnostic testing - cure.
T
Tim belcher
2005 sprinter 2500
2.7 Mercedes five cylinder
The codes will have a Pxxxx format - thats what we need to be able to help you.
P2051 can be caused by a bad injector. P2047 can be caused by a blocked fuel filter.
You really need to get this on STAR to diagnose it properly
T
Tim belcher
2005 sprinter 2500
Using a versus pro scanner
New injectors have been installed. Two fuel filters have been tried with no results
In that case it definitely needs to go on STAR as STAR can test individual components to isolate the fault.
T
Tim belcher
2005 sprinter 2500
This unit does that as well
Steve@Avantgarde
Bristol/Somerset
The versus pro scanner is nothing like STAR. STAR is built for MB and has much more in the way of guided tests, actuations and actual values.
I had one on demo from Snap On and thought it was nothing more than a glorified code reader.
www.W140.co.uk&www.r129.co
