ABS/ESP/BAS Fault, no communication from SAS
Danhunt
Boston, Lincolnshire
W210 2000 2.6L
Hi first post as i just ventured into the merc world.
i have a slight problem
i have a 2000 w210 2.6l v6 auto
ESP/BAS/ABS errors reading but caused by SAS not communicating. i have 3 sensors now all second hand but surely all 3 cant be dead. on Star it has no read out value when wheel is turned with any of the three installed which is leading the garage to believe it is a wiring fault.
could someone be so kind as to tell me where the red and blue wire to the SAS goes and this is the only dead wire i found when i was testing them with a voltage meter.
also what should the others be reading. i had 2 live and one neutral (i assume)
i also changed the BLS first.
Help Im running out of ideas and dont wanna spend silly money fixing it.
WG M-B
North west london
C63 Wagon in black
I know there is a fuse under the rear seat for this in the row where the battery is
D
Danhunt
W210 2000 2.6L
i checked all fuses with volt meter. do you know exactly which one is ?
WG M-B
North west london
C63 Wagon in black
Not from memory no
But it's under the rear seat if it's blown
D
Danhunt
W210 2000 2.6L
i will keep going at it and recheck them all and check all wiring to them
D
Danhunt
W210 2000 2.6L
also surely if the fuse was dead there wouldnt be 2 wires with a voltage output going into the Steering angle sensor. it just doesnt seem to be communicating with wherever the data gets processed. is it the BAS esp control unit where it goes??
D
Danhunt
W210 2000 2.6L
i have a second untested BAS control unit might stick that in and see
D
Danhunt
W210 2000 2.6L
am i right in thinking the control unit is under dash on passenger side
D
Danhunt
W210 2000 2.6L
Anyone know the voltage the wires should have and corresponding colours
ABS is the base system, BAS rides on top of the ABS to take control of individual braking and engine control. ESP rides on to top of the BAS to take car of the car skewing.
Looks like a speed signal gone for the ABS, the others cannot work with no ABS
You have changed the brake lamp switch.
