ABS/ESP inoperative (Yes, another!)
steve gooding
2012 C220 Sport CDI estate
Hi guys.. seems as tho this topic has been covered to death recently. I’m getting this warning intermittently, came on again on my way home today.
A mate works for an independent VW garage, just wondering if the gear they use for OBD2 fault reading would be compatible with the system on my 2012 c220?
I’m hoping it’s just a sensor..
Cheers,
Steve
shine
Hampshire
CL 500.W216 + C300 Coupe AMG Line 2018
Welcome to the inoperative ABS/ESP club. It's a conspiracy by MB
If your mates kit is VAG VCDS or equivalent no it won't read MB codes.
If it's a high end multi vehicle reader then it might.
steve gooding
They do work on other brands, so it might work. Just don’t like the idea of paying £50 for someone to plug in a lead and press a few buttons, literally a couple of minutes work max. But if that’s what I need to do then so be it.... I’ll try my mates gear first.
steve gooding
Also wondering why the run flat indicator is inoperative too. Is there a sensor on the hub that reads all the info from the wheel?
I’m new to the MB world, so there’s loads I need to learn. Might have to bear with me...
star
Reading
Smart + others :)
Use a indie regularly and I expect it to be FOC or not as much as £50. Or you could purchase the equipment and then it would cost you nothing?? :)
As above Vag specific reader will not work, but a generic one would.
star
Reading
Smart + others :)
I expect you have a wheel speed sensor fault.
steve gooding
I’ve only had the car since January. I had it serviced by MBS in Feb, but I’m not sure one visit warrants a FOC fault check lol..
I’ve been looking at buying my own reader, but knowing which one to get is a bit of a mine field. Any pointers?
star
Reading
Smart + others :)
One of the other member will be able to help with which code reader to get as we only use star diagnostics.
For a cheap solution for basic use the iCarsoft i980. For more functionalality there are a few but the common one on here is the iCarsoft v2.0 or MB II (there's an MB II for sale on the forum at the moment). There are others as well. Carly for Android, Autel, Launch all do MB specific ones but nothing is as good as STAR.
There are two types of tyre pressure monitoring. The active type has pressure sensors in each wheel and can display the pressure.
The passive tyre pressure monitoring measures wheel rotational speed so if it can't get a speed reading from a wheel it will go inoperative. It would seem you have the latter.
steve gooding
Yea, I definitely don’t have tyre pressures displayed..
Many thanks for all your replies
John Laidlaw
Wirral
Land Rover Discovery 4
As a comparison Inchcape tried to quote me £156 for a diagnostic to ascertain my AC woes ....until I reminded them I had Tier 1 so will be paying zilch. This is the real upside of using an Indy such as yourself Ian
steve gooding
A friend at work was charged £100 at a Nissan dealer for fault code reading.
I’ve always used independent specialists, get a much more honest service at reasonable prices..
John, I’m sure I’ve seen your name before. Were you a member on any VW forums?
John Laidlaw
Wirral
Not VW forums no Steve but been on Volvo one ?
Where you based?
steve gooding
  • #17
Where you based?
I’m in Southampton (currently a nervous wreck after watching the footy)
John Laidlaw
Wirral
Lol I can imagine, one of my partners in work is a baggies fan though so could be worse?
I should have twigged when you said you’ve used MBS, well respected on here you’re lucky!
Have a couple of suppliers and customers down your way?
steve gooding
  • #19
Possibly. Where are you based? Are you in electronic design?
Just sure I’ve seen your name before.
2012 C220 CDI Sport
John Laidlaw
Wirral
2012 C220 CDI Sport
On the Wirral Steve , not electronic stuff no- fluid power in large marine types...(oh and previous F1 refuelling stuff when it happened)
