Autobox settings
kenya1993
This is my first post having just joined the forum. :)
I have just taken ownership of a C220 CDI sport with the automatic gearbox and would appreciate it if anybody could advise on the best settings to use for 'normal' driving. The box comes with:
M - Manual (I understand this setting)
S - Sport
C - Comfort
Having read the car manual it advises that for everyday diving the S - Sport mode should be used, and that C - Comfort is actually for driving in slippery conditions (Ice etc.)
Is this correct ? and should I not be using the C - Comfort setting for everyday use ?
I thought that the S - Sport mode was for more aggresive driving and not normally for everyday use :confused:
Any advice would be greatly appreciated.
You can use what ever mode you like
S is a first gear start with higher shift points
W is a 2nd gear start
There are hundreds of post here on this subject
whitenemesis
CLS55 AMG '05
My handbook defines S mode as standard
As Malcolm says C, (or on some models W for Winter) mode is a more gentle start. The car will also reverse using a different gear (I can never remember if it's higher of lower!!) so maneuvering is easier especially in slippery conditions
colechelle
Resigned
i keep my C320 in c, gives me 3mpg more, air con turned off, seeing 30mpg every day now!
K
kenya1993
Thanks Guys, I really appreciate your responses :)
So if I continue to drive in 'C' mode I won't be causing any undue stresses on the engine / gearbox when starting off in 2nd for example ?
I must be honest I bought the Sport model because I liked the styling and looks of the car. Not because I intended to drive it in a 'sporty' manner.
I have found the drive in 'C' mode a much more relaxed approach and if I am going to return a better MPG also then this is even better.
Cheers,
I keep mine in C for the best part, the wheels do not spin and much smoother with better MPG,, if you want to have fun, then the S mode is there for you:D:D
Rory
Cheshire, UK
I drive mine (C270CDi) in S mode, and I'm the world's most relaxed driver.
I just find it's altogether too slow to pick up from rest in C, and if you need to boot it, say to get on to a fast roundabout, then it still shifts down to first, but does so with an unMercedes-like jolt.
I have too many gear and loads of torque so I leave it in C unless I'm at the Severn TAG Grandprix :twisted:
whitenemesis
CLS55 AMG '05
Agree, I do the same.
Except when driving my mother around.:rolleyes:
M6AJJ
Norfolk. UK
v222 2014 350
Me too, S all the time unless there is Ice about.
Makes no difference whatsoever to the MPG, but take off from a standing start much quicker.
