Automatic transmission dipstick, R129
Torrean
Bracknell
Mercedes r129, 320, 2000
Hi Guys, strange question, does anyone know the length of an Auto transmission dipstick for an R129. I have a dipstick but it seems too long.
Thanks.
Thanks.
They are all too long , designed for different dipstick tube heights . It’s the stopper before the plastic measuring part that sets the height
Measure the oil when it’s hot , engine running , gearbox in Park on a level surface :D
ajlsl600
france
50 k + cars and no way to check trans oil without purchase an extra !! Should be a warning really.
T
Torrean
Bracknell
Thanks guys, the issue I have is that I’m not sure when I hit the bottom of the sump as I can feel a resistance when I think I have reached the bottom but if I push the dipstick it goes in further, only this I can think of is that the dipstick is bending at the bottom, hence the question about the length of the dipstick.
You aren’t reaching the bottom , the lump above the last couple of inches is stopping in a recess above the oil , the going in further is the flexible tube bending above .
What oil Reading are you getting
Is this the 722.6 gearbox? There are several others used on 129s.
T
Torrean
Bracknell
That’s the problem, I don’t know! :)
Ok 722.6 then.
On the dipstick there's a plastic lump at the point the flexible metal part joins the flat blade. That is designed not to go past the measuring point.
The initial resistance you're finding is probably the end of the stick hitting the join at the end of the tube before going into the gearbox.
T
Torrean
Bracknell
Ok 722.6 then.
On the dipstick there's a plastic lump at the point the flexible metal part joins the flat blade. That is designed to to go past the measuring point.
Thanks for this info, sorry for being dumb, at what point do I stop!
T
Torrean
Bracknell
:) Cheers, from a Dummy!
If in doubt measure the length of the tube and compare to the dipstick. That will tell you where the join is.
