Automatic transmission fluid filler pipe
misterbee
Reading
Mercedes(2000) C class 2.0
Mercedes C Class (2000) 2.0
Dear All, I would very much appreciate assistance as to how one can test fluid levels and top up as neccessary,( if this is possible). I have pictures under the bonnet, if that helps. In Advance; Thankyou, Brian
The filling and dip stick tube is at the rear of the engine with a cap on top, it is up against the firewall.
M
misterbee
Reading
Thankyou . its a strange looking cap , is it just a case of popping it off ? i am assuming i will require a replacement cap though if freely available, thats not so much of an issue, Brian
If its sealed, break the seal, it will stay on without the seal, so no need to replace
Brianooo
Preston Lancashire
Mercedes E300TD Avantgarde estate 1998
I have a 1998 210 e300td and when I wanted to change my transmission oil I found that I had to purchase a dip stick from Mercedes (their description was a gauge). I was thinking it would just be a dipstick for the gearbox but when I came to use it, it was way too long to leave in place all the time. After the transmission oil change it was wrapped up and placed in the boot and the cover refitted to the filler tube.
M
misterbee
Reading
Thankyou
M
misterbee
Reading
Thankyou so much for the advice
