Auto Addict
- Jul 18, 2017
- Location
- North Midlands
- Blue Efficiency C Class Estate
Can it check the battery ECU, apart from fault codes, charging rate etc.
Not quite sure I understand your question?
Ah ok. Sorry (after all that) but I can't answer as I don't have one. There are a number of live data views that will show you what is actually happening in the car in realtime and I think battery voltage is one of these but charge Amps is unlikely unless it derives it from battery voltage.Sorry, Ok, I know the MBII can read fault codes etc., what I wondered was, does it give more information say on the battery ECU, charging rate etc.
You'd be better contacting one of the Authorised suppliers, who are often very helpful.
iCarsoft have a reputation for not answering emails.
Pretty certain it shows voltage readingsCan it check the battery ECU, apart from fault codes, charging rate etc.
Did you find out where you go, to put the EPB in service mode?Extremely handy bit of kit!
I keep finding new capabilities with each use. If you've got the time and the inclination, with a fair bit of deep diving, it can throw up some very useful data. For example, it will show the gearbox oil temperature, that being essential for correct fluid level readings.
And yes, to back up what Sub has said, it can indeed reset the service indicator.
Best
Bertie.
Thanks.Afraid not as my W220 hasn't actually got that particular feature. I'm sure it's there somewhere though!
I will say that a bit of digging can reveal all sorts of interesting stuff with the MBII.
Hope you find what you're looking for, Sub!
Best,
Bertie.
