Bouncing door locks
Status
Not open for further replies.
I need an Email address please
Alex Crow
Super Suffolk
............Im pretty sure it aint a spring thats broke mate, im fairly sure its the sensor that is integral to the door lock mech that has failed and thus cannot now work out what position the lock is in...............
it actually IS a broken spring, but finding one like it and taking the mech apart to fit it will be mega tricky. the lock has a motor, but no sensor, and so has no idea what position the latch is in btw.
Forest Driver
New Registration
Info please
Hi I was reading this thread and saw the offer of info on replacing the lock actautor please could you send the info to me too as my wifes car has the same fault - email address in my profile - many thanks Neil:D
Hello Neil, and welcome,,I cant use that Email address as I cannot attach things to it, if you pop it up here you can edit it out within 4 hours of posting
Pian Eel
New Registration
Yes same here
I have just signed on to this club and Im not quite sure of how it works.
I own a C180 Komp (2003) and have the same problem with the passenger door.
Do yo think that you can pass on the info to me too, please.
Hello and welcome,,I most certainly can pass on the info, can you pop up your Email address this evening after 6pm
tsbhap
New Registration
Jumping door knob
Hi Malcom,
I have a E270 with the similar problem. If the problem isthe motor and needs a new lock can you send me the instructions please?
Hassan
Welcome Hassan to the forum I need an Email address please
Developer
S212 E63 S 5.5 biturbo
Hi Malcom,
Hassan
On the info Malcolm is going to send there's an instruction (9) to remove the front door lock cylinder. To do this, pull off the rubber door seal adjacent to the lock where you will see a hole giving you access to the torx bolt. I also found that once you had drilled the blind rivets out at section 3 you could flex the window running rail enough to get the motor past it without actually removing it (the running rail).
Welcome Claud and details sent :D
Members please note I am away for 2 weeks as from the 06-09-10 so nothing sent out for a while
booth
nottingham
2003 230slk-2003 c220 cdi coupe evo panarama
Hello Malcolm,
I also have the bouncing button problem on the passenger side of a c203 coupe.
Would it be possible to send me the instructions for replacing the lock.
Best Regards
Philip.
thompy
Belfast
2004 c220 CDI Avantgarde
malcolm your a busy man sending these emails lol.
same thing has now happened to my c220 2004 passenger door. (looking like a common fault?).
could i have the emails when you have time as i know your only home from holiday.
cheers paul.
pibisb@yahoo.co.uk
harrisis
w203 C-coupe 220Cdi
w203 door locks
me 3 :p please
Malcolm,
I also have the bouncing button problem on the passenger side of a 2002 c203 coupe. Would it be possible to send me the instructions for replacing the lock??
Many thanks!
I have sent them harrisis
Status
www.W140.co.uk&www.r129.co
