"Can you imagine TMD the largest brake manufacture in the world adding some squeal mixture to the compound to some of their brands"
I liked that phrase "squeal mixture" thats what I used to call an old girlfriends favourite drink.
I'm pretty sure TMD don't add Champage to the friction mix though.
I have in the past often cleaned off the rusty outer edges of my discs with an angle-grinder, and removed the 'lip' that occurs through wear. Naughty but nice.
Baz
That seems a little drastic but I have myself resorted to using a small hammer to remove that rusty lip, and to sanding back glazed pads. :Oops:
However I was referring to the skimming of disc braking surface faces.
were the front discs drilled?Hi guys,
Just to throw my 2 cents worth into the pot!
For Pagid Front and rear pads & discs it comes to £269.28 - with the forum discount is brings it to a shade over £200 - £201.96 with free delivery to collect from 100 stores!
Pagid Brake Disc (FRONT)
Part Number: 104221648
Web Price: £54.60 (Priced Per Disc)
http://www.eurocarparts.com/search/104221648/p/car-parts/
Pagid Brake Disc (REAR)
Part No.: 104221618
Web Price:£35.94 (Priced Per Disc)
http://www.eurocarparts.com/search/104221618/p/car-parts/
Pagid Brake Pads (FRONT)
Part No.: 101221098
Web Price: £48.00 (Priced Per Axle)
http://www.eurocarparts.com/search/101221098/p/car-parts/
Pagid Brake Pads (REAR)
Part No.: 101221078
Web Price: £40.20 (Priced Per Axle)
http://www.eurocarparts.com/search/101221078/p/car-parts/
Atleast this gives you a good idea of how much they would be to replace with premium, original quality parts
Patrick
Apologies for dredging up an old thread...
I've just got my A200 back from the dealer and they're advising new pads and discs after 10,000 miles!
"Front disc condition 25.81mm (min 26mm)".
Do Mercedes make their discs out of cheese? Surely the discs should last longer than a set of pads! Plus, if it's below the minimum, is it safe to drive?
/Moog
As ^ , second opinion time . I have just startd my second set of pads on my front original discs of my E320 ...now at 83k miles .Apologies for dredging up an old thread...
/Moog
I've complained to Mercedes, yet to have a response.
