brake pads and discs
Dosco
W211
The last set of 'genuine' MB front pads I purchased for my old E240 had PAGID stamped into the metal back plate as did the ones I took off and they did the job they were supposed to do.:cool:
WG M-B
North west london
C63 Wagon in black
I have also had genuine mb pads with pagid stamped on them. Never a problem.
Robbostanhill
Dartford, Kent, UK
E270 Estate 2003 and *Her* C220 W203
'tis done...
3 hours and well worth the effort.
A pair of drilled discs £62
A set of EBC Ultimax pads £41
A pair of disc retaining bolts £2.50
As you can see there were some "issues" with the originals, and the pads were fubarred but still had loads of wear left. Whoever fitted new pads to those discs should be castrated with a blunt razor blade.
The new pads were painted on the faces with a "Bedding in" coating. This appears to assist in the process of bedding in and also burning off the crap left from fingers when assembling. I cleaned the braking faces of the disc first, but not all obviously came off....given the smell and the smoke after some "enthusiastic" progressive braking to get things warmed up....
Rears to do...... soon
Frontstep
T210 320cdi
"Can you imagine TMD the largest brake manufacture in the world adding some squeal mixture to the compound to some of their brands"
I liked that phrase "squeal mixture" thats what I used to call an old girlfriends favourite drink.
I'm pretty sure TMD don't add Champage to the friction mix though.
Well you do have to laugh about it ;):D
jefrs
Berkshire
S210 98 E320 Estate Av petrol full load
I have in the past often cleaned off the rusty outer edges of my discs with an angle-grinder, and removed the 'lip' that occurs through wear. Naughty but nice.
Baz
That seems a little drastic but I have myself resorted to using a small hammer to remove that rusty lip, and to sanding back glazed pads. :Oops:
However I was referring to the skimming of disc braking surface faces. :shock:
Robbostanhill
Dartford, Kent, UK
Edges
I too have resorted to spinning off the "Edge" that appears if only to allow easier pad removal and less crap breaking off during use.
The recent brakes refurb on the fronts was long overdue, and even a skim up of the discs wouldn't have sufficed. After all they are the only thing keeping you alive when you need them the most...
Frontstep
T210 320cdi
Nothing wrong with a deftly wielded angle grinder.
coventryslk
Coventry
W204 CDI Sport
Hi guys,
Just to throw my 2 cents worth into the pot!
For Pagid Front and rear pads & discs it comes to £269.28 - with the forum discount is brings it to a shade over £200 - £201.96 with free delivery to collect from 100 stores!
Pagid Brake Disc (FRONT)
Part Number: 104221648
Web Price: £54.60 (Priced Per Disc)
http://www.eurocarparts.com/search/104221648/p/car-parts/
Pagid Brake Disc (REAR)
Part No.: 104221618
Web Price:£35.94 (Priced Per Disc)
http://www.eurocarparts.com/search/104221618/p/car-parts/
Pagid Brake Pads (FRONT)
Part No.: 101221098
Web Price: £48.00 (Priced Per Axle)
http://www.eurocarparts.com/search/101221098/p/car-parts/
Pagid Brake Pads (REAR)
Part No.: 101221078
Web Price: £40.20 (Priced Per Axle)
http://www.eurocarparts.com/search/101221078/p/car-parts/
Atleast this gives you a good idea of how much they would be to replace with premium, original quality parts :cool:
Patrick
were the front discs drilled?
coventryslk
Coventry
W204 CDI Sport
details
You have some ATE pads advertised on your ECP ebay outlet with product details stating they are ceramic, but the part number is for the original pads.....
13.0460-2733.2 (Original, as on your site)
13.0470-2733.2 (This is the part number for ceramic pads!)
Pathfinder
Gourock
In my book, them back plates would have been changed at the same time, they are done. Kaput.
Moog
A200 AMG / 2015 / 1.6 Petrol
Apologies for dredging up an old thread...
I've just got my A200 back from the dealer and they're advising new pads and discs after 10,000 miles!
"Front disc condition 25.81mm (min 26mm)".
Do Mercedes make their discs out of cheese? Surely the discs should last longer than a set of pads! Plus, if it's below the minimum, is it safe to drive?
/Moog
JBell
Torquey
C350 CDi Estate (GAD Edition)
/Moog
I would get a second opinion and have them measured, 10k is nothing disks should last at least 2 sets of pads
/Moog
As ^ , second opinion time . I have just startd my second set of pads on my front original discs of my E320 ...now at 83k miles .
John Laidlaw
Wirral
Land Rover Discovery 4
Even on mine I’m on my second set of pads and original discs c29k. Discs I think I’ll have to replace with the next set of pads in 5/6k so the discs will have covered near 35k.
Usual rule 2 sets of pads to 1 set of discs
We've had our 210 for 23k miles. We have yet to change pads or discs on it. Definitely get another opinion.
Moog
Hello all
I thought I'd follow up here to let you know what happened.
Recap: Got my A200 AMG back from it's 2nd service (10k miles), to be told that the brakes and discs were below minimum and needed replacing.
I got a second opinion and they said that there was about a third left on the pads, so they'd be ok for a while. The discs however showed very little wear and were like new.
I've complained to Mercedes, yet to have a response.
Last Merc I'm buying!
Thanks all for your feedback.
/Moog
