C class interior door handle.
Pritchsas
Wolverhampton
Mercedes c class sport
Hi all ,
I purchased my first used mercedes last week and unfortunately already have a problem.
The rear inside door handle now fails to open the door and the resistance has gone off the handle leaving it to flap about.
I'm a hands on type of guy so don't mind fixing it myself if someone could point me in the right direction.
Many thanks
Ps It's a 2010 c class cdi sport.
The clamp that holds the outer sheath of the door handle cable has broken away from the door card, mercedes say a new door card at £400,,, the fix is to bond something to the back side of the cad that will allow the cable clamp to be fixed to the card, it should be easy enough to come up with a fix.
Modern polyurethane glues are stronger than what they are stuck to
P
Pritchsas
Wolverhampton
Thanks for the reply Malcom.
Do you know of any links where it shows you how to remove the door skin ?
With an Email address I can send you that info.
I only have the front door one printed off, and I have sent that and I will print off the rear door shortly and send it.
P
Pritchsas
Wolverhampton
I don't seem to have received the first one you posted?
I have sent the rear door liner info, please check your junk box
P
Pritchsas
Wolverhampton
Email received and door fixed .
My wife thinks I'm a very clever guy thanks to you.:)
Kindest regards
Steve
apj0524
Somerset
2009 C220 Cdi W204 Saloon Sport
Door Panel details
This seems to be what has happened to mine, see separate post, Television please can you email details of the W204 Drivers front door panel to:
andyjudkins0524@hotmail.com
Regards
Andy
tom041098
East Sussex
www.youngcardriver.com
C220 Estate 2009 Diesel
C220 Estate 2009
Morning,
Same thing happened to my 2009 C220 this morning. Pulled the handle - got stuck! Had to put the window down to get out. Please can you send me instruction for the front drivers door panel.
Thanks in advance.
Gareth
Morning,
Thanks in advance.
Gareth
Please activate your Email address in the user CP top left.
L John
W204 C350 Petrol Elegance
Malcolm, would you send me the info on the front door panel please?
I have sent it John, another case of where we pay for mercedes faults.
L John
Many thanks Malcolm.
basher08
ingleby barwick
C200 sport/2010/2litre
Same problem
Hi, I have the same problem with my 2010 c200 drivers door. Could you possible email me the sam documentation?
Best Regards:D
Time for a how to guide in the DIY section!
Dougie83
Tyne and wear
C220
Drivers inside door handle
Can anyone help me? My drivers door handle doesn't work.
