C220 CDi Estate 2012 Manual Juddering
steve gooding
2012 C220 Sport CDI estate
I also had this problem on my w204 c180 of 2011 with now almost 160k miles.
It is much worse when I transport 4 persons in the car, and can be avoided depending on how the clutch is used. It also comes in an intermittent way, especially after long session of stop and go (like in a traffic jam). I believe some surface becomes hot or polished, causing the problem until the surface goes back to normal.
A clutch replacement doesn't seems to be the solution, as the clutch never slips otherwise
I can pinpoint when mine appears, and it’s the opposite to what you describe. I thought it had disappeared after having my engine and gearbox mounts replaced but it does occasionally reappear.
Stop start slow moving traffic I have no problems at all, which is odd because the clutch is surely getting hotter as it’s used more. My clutch judder appears when I’ve been on a long motorway run and haven’t used it for say an hour or so, then when I pull off and the first time I have to drive from a stand still the judder is there and quite bad. I have learnt to live with it as it’s not every day I do long motorway runs, but is annoying.
A lot of manual haters on this forum, and I have to say, I am wishing I’d bought an auto.
I had no preference when I bought the car but had I joined this forum before my purchase I don’t think I’d bought a manual...
M
C220 Cdi Estate Manual 2012
  • #42
It sounds exactly like mine !!
As you have probably read i have replaced clutch etc. but it started again after only about 8k.
About 8 9 months ago i was really fed up with it so i got the car up to temp and put it in 4th gear and did a cpl of standing pull away starts riding the clutch, the smell was awful !! Touch wood its been ok ever since, but the test will be this weekend as i'm going away, about 200 miles most of it motorway, fingers crossed.
I wouldn't advise anyone to carry out the same as i did tbh i was that p****d off with it i really didn't care.
That said i do love my c220 sport but sometimes think an auto might have been a better option but i wanted a manual so at least i brought what i really wanted.
I will let you know how the journey goes.
Touliloup
W204 C180 2011 post lift model
Actually make sense, when I'm in a traffic jam, it's almost always after being a long time at high speed on the highway. So it might not be the stop and go, but maybe the long motorway run that precedes.
steve gooding
Yea, still a lot of love for mine too (same model as yours). As I said, I had no preference between auto and manual when I bought mine. I spent months looking and mine just ticked all the boxes... should’ve had an extra box on my checklist for transmission lol...
Touliloup
Replacing an automatic gearbox and dealing with the dilemma whether to replace the fluid or not according to Mercedes is no fun either... automatic gearbox also do fail, and it's not the price of a clutch!
steve gooding
A new clutch won’t solve the judder. I think it’s down to the dual mass flywheel, not just on Mercs but on other cars too. I had a Passat diesel before the merc which suffered with the same, albeit not as often and not as harsh, but there was a very slight judder there..
ajlsl600
france
Hi All,
I am new to this site so hello to you all.
I have an annoying problem with my c220 CDi Estate the car is manual and a 2012 model with the amg alloy pack etc
When the engine is warm (running temp 90 degrees or there abouts) I get a judder when pulling away in first gear from a standstill. fells like anywhere from the gearbox to the rear axle drive wheels. When its cold or hasn't been driven very long at temperature its fine, but as soon as you've done a few miles at temperature the judder appears but only from a standing position, if the car is at temp and parked up for a few mins or so with the engine off when you restart the engine and pull away it will judder, I can only imagine the problem is heat related rather then mileage. The juddering is inconstant sometimes worse than others. I have also noticed that when standing still (with eco off) if the clutch pedal is depressed fully the engine revs increase to around 1000 rpm when clutch is released they drop back to normal running speed. The car was checked by an independant MB mechanic who told me there was nothing wrong with the car really but did advise that maybe the throttle pedal needed replacing as this was a common fault, it was replaced but made no difference.
Other than this problem the car is fine returning in excess of 60 mpg on long runs, any help would be much appreciated.
oil on clutch plate . ?
yeomiuk
W204 c220
Hi have the same problem but it only does it after 3 hours of driving ...I've have noticed if you turn off the ECO button off its don't do it
yeomiuk
W204 c220
Hi All,
I have the same problem with mine ..it only does it after driving 3 or more hours ..I have noticed if you turn the ECO button off it doesn't do it so much which is strange
yeomiuk
W204 c220
Here we go again 9 months later and around 9000 miles and the clutch judder is returning. Admittedly not as bad as before YET but im sure it will get worse.
When a long distance has been covered and the engine is warm if you stop and pull away bingo theres the judder, also it can judder when changing to 2nd and 3rd but this is intermittant. Looks like a £1100 clutch change was a waste of money.
Any help would be appreciated otherwise it looks like getting rid as i aint been impressed with this car for the 18 months or so i've owned it was hoping for better from Mercedes.
Did you ever get to the bottom of this problem ?
Tel: 020 8863 9233
