Car running hot e250 cdi coupe 2015
Jessehollywood
E250 cdi coupe
My car is running hot but not over Heating
Plus there's black exhaust soot all over the back of the car
Iv took it to Mercedes twice for them to tell me everything's fine but ino the car is not running fine
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Howdo. How do you know it's running hot? Does it go much above 90/95 on the temp gauge?
Jessehollywood
E250 cdi coupe
Temp gauge is normal on the dash but after 5 mins of normal driving engine smells hot and if you stand next to the car heat pumps out of the front wheel arches and exhaust pumping hot air out and black soot over the back of the car
My friend has the same car with the same engine and he's does not do it
Jessehollywood
E250 cdi coupe
It's quite concerning seeing as the car has only covered 25000 miles and is still under warranty till January 2018 but Mercedes are adamant the car is fine which refuse to believe
Yugguy
Rugby, UK
Try another dealer or perhaps get an indy assessment.
tode
NW FRANCE
S350 btec 2011
There should definitely be no black soot coming from the exhaust (or elsewhere ;) ).
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
Agree with this modern diesels should not have black sooty exhausts.
Worth checking to see if the exhaust has been messed with unless you have had it from new.
Robin
Wabby
MY17 C250d Coupè
Could be doing a regen.
That would explain the excess heat ... maybe even *some* soot.
Jessehollywood
E250 cdi coupe
Mercedes said regen but I can't believe at such an early stage it's doing a regen ....it's sad because I have not had the car long and now I'm reluctant to just get rid as I fear with it running this way it will cause damage to the engine in the long run
malcolm E53 AMG
A full DPF regeneration on mine can take 10-15 miles and if you turn the engine off mid-way through the regen it will continue at the next start-up when up to temperature. The heat coming from underneath the car can be quite disconcerting at first until you get used to the fact that the engine will do this every 300-500 miles and it is quite 'normal'
What type of motoring are you giving the car is it used for a lot of short runs?
Jessehollywood
E250 cdi coupe
I cover about 800 miles a week with a mix of A roads B roads and occasion m25 Iv took it on several 30 mile motorway runs to see if it's the Dpf ...but still I feel excess heat I'm off to a garage this morning for more checks
malcolm E53 AMG
Does sound like there is a problem, hope you make progress with it this morning, get them to check for a transmission oil leak if that gets on the exhaust it might show similar symptoms
Srdl
Hampshire
GLC43 AMG 2018 (X253)
How long? One option might be to return it to the selling dealer and ask for a refund - but that will depend on how long you have had it.
There is certainly something wrong. In the seven years that I have had mine I have never been aware of a regen taking place other than a slight burning smell on rare occasions when I get out if the car.
I am not technical enough to make any suggestions but I wonder whether the previous owner did something to the DPF or something associated with that system?
