Central Locking
muzzere320
Not sure if this belongs here or in the Bodywork section but here goes.
I can't get into the boot. Up 'til this morning no problems - unlock the car on the button and open up by pressing the lock. As of this morning although all four doors are unlocking the book remains locked and the key will not ulock it.
Any ideas on what the problem might be? Also is there a route in from the passenger compartment without damaging the seats/trim - if so any guidance would be appreciated
Pete
type49
Very strange that the key won't unlock it. Do you know you have to turn it 45 degree clockwise & then pull the handle?
muzzere320
Type49
Thanks for that the car is a saloon so there is no handle, but I have tried pushing the button (the lock is the button) in with the key in every position I can find - but no success
Cheers
Pete
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
The boot lock tends to seize up as the key is seldom used, squirt some lubricant into the lock then work the key back and forwards, it may take some time but the lock should free off.
There is no way I know into the boot from the passenger compartment without causing damage to the seatbacks, sorry.
muzzere320
Thanks for the responses.
I went and had another go during my lunch break. The problem turned out to be the catch/lock not being fully engaged. While fiddling around with it I noticed the bottom edge of the bootlid flexing which seemed a bit odd; so I tried to nudge it so it closed properly - no joy. So, I somewhat gingerly grabbed the bottom edge and gave it a tug - hey presto the lid popped open:D. It seems the catch had engaged enough to keep the boot closed but not enough to fully engage the locking system. On looking at the mechanism I noticed it was covered in grime so I'll give it a good clean & lubricate it at the week end.
Cheers
Pete
eric242340
Banned
China
Cheers
Pete
At least you posted back and informed all. Thats all people expect - to be informed of the outcome. THANKS:D
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
while we are on the topic of boot locks, what key can you use to open the lock ? the same key that you use to start the car with ? doesnt work on mine, maybe i need to clean the lock as C220GJS says
cheers
anyweb
Ron Palfrey
C280 Elegance 1994
Sometimes my boot seems to stay locked if I haven't had it open for a few weeks. However, it is just the rubber sealing moulding that sticks to the lid and holds it closed - just requires a tug, as it has in fact unlocked.
Ron
C220GJS
Shotts, Scotland.
Ron
Wipe some petroeum jelly (vaseline) around the seal, just a very small amount will stop it sticking.
